2 TB 3.5" Hard Drive
$79.95
Product code: IF107-087
$79.95
Product Overview
Important: To ensure compatibility with the 2009 and 2010 21.5" or 27" iMac, the replacement hard drive must be of the same brand as the original. The model number of the hard drive does not matter as long as the brand matches. 2011 and up iMacs cannot be supported by us.
Serial ATA interface. Works only in iMac G5s and Intel iMacs (excluding 2011 and up 21.5" and 27" models). This drive has a form factor of 3.5".
Compatibility
  • 1.8, 1.9, or 2.0 GHz 17" iMac G5s (EMC No. 2055)
  • All 20" iMac G5s
  • All Intel iMacs (excluding 2011 and up 21.5" and 27" models)
  • All G5 Power Macs
Product Details
  • Interface: SATA 6.0 Gb/s
  • Dimensions: 3.5" (88.9mm) wide x 1" (25.4mm) tall
  • Capacity: 2 TB
  • Cache: 64 MB
$79.95 Western Digital
Condition:
New
Notes:
Model #: WD20EZRZ
Speed: Intellipower
$89.95 Seagate
Condition:
New
Notes:
Model #: ST2000DM001
Speed: 7200 RPM
Add to Cart
Replacement Guides
Apple Time Capsule Model A1302
Difficulty: Moderate
Asus F201E
Difficulty: Easy
Dell OptiPlex GX260
Difficulty: Easy
iMac G5 17" Model A1058
iMac G5 17" Model A1144
iMac G5 20" Model A1076
iMac G5 20" Model A1145
iMac Intel 17"
iMac Intel 20" EMC 2105 and 2118
iMac Intel 20" EMC 2133 and 2210
iMac Intel 20" EMC 2266
iMac Intel 21.5" EMC 2308
iMac Intel 21.5" EMC 2389
iMac Intel 24" EMC 2111
iMac Intel 27" EMC 2309 and 2374
iMac Intel 27" EMC 2390
Compatibility
1.8 GHz (EMC No. 2055)
2 GHz
1.9 GHz
1.8 GHz
2 GHz
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
2 GHz (EMC No. 2105)
2.16 GHz
2.33 GHz
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2266)
3.06 GHz (Core 2 Duo)
3.33 GHz (Core 2 Duo)
3.06 GHz (Core i3)
3.2 GHz (Core i3)
3.6 GHz (Core i5)
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz (EMC No. 2267)
iMac Intel 27"
2.66 GHz (Quad Core i5)
2.8 GHz (Quad Core i5)
2.8 GHz (Quad Core i7)
2.93 GHz (Quad Core i7)
3.2 GHz (Core i3)
3.6 GHz (Core i5)
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
Stories
My Problem
Old hard drive would no longer boot up or mount
My Fix
Straightforward. Went exactly as the repair guide said it would
My Advice
If you follow the procedure from ifixit, you should have no issues
My Problem
Repair was pretty easy except for the fact that after everything was complete it turns out I also needed a " owc temperature sensor switch " replacing the oem hd require this cable which connects to the hard drive and temperature sensor ...if not connect the fan thinks the hard drive is failing and speeds up on full steam and becomes extremely loud . 60$ spent getting there part now I have to take apart iMac again
My Fix
Easy repair ,take your time but super easy 30 mins repair time 1 hr if u take your Time .
My Advice
Pick up a owc temperature sensor cable of your doing a hard drive replacement
My Problem
Lost hard drive on computer. All tests diagnosed the hard drive as dead. Taking it to an Apple Dealer was out if the question. More to repair than the computer is worth.
My Fix
Repair was easy thanks to your easy to follow instructions as well as tools that can be purchased from your website. I have already fixed a friends computer that had similar issues.
My Advice
Check out iFixIt first!! If it can be fixed, this is the place to look. Will be coming back here in future if any other problems arise.
My Problem
hard drive died
My Fix
Easy
My Advice
Plug and Play. time capsule recognized the new drive and immediately stared backing up all our MAC computers
My Problem
hard drive died
My Fix
Easy
My Advice
My Problem
My machine was beginning to run slower and with Safari the petty beach ball was appearing a little too often before the web page would load. Then the screen pop panic appeared, all white with no possibility of booting to the desk top screen.
My Fix
With some online research I stumbled upon the IFIXIT site and that was enough to give me the courage top attempt the repair myself. I also checked around with local Apple repair spots that quoted +$300 to fix with parts and labor. With the help of IFIXIT and a ton of savings I was able to get my machine up and running like th issue never happened.
My Advice
The one very important piece of advice is that this fix was made that much easier because I use the Time Machine auto backup program with an external hard drive, I would highly reccomend that if you have an older machine that you make sure that you have back ups ! With that its super easy to restore.
My Problem
iOS could not find the start volume but with a copy on a external hard drive it works (very slow but it works)
My Fix
With the description from iFixit it takes me not 15 minutes to replace the hard disk
My Advice
Perfect description
My Problem
The 1TB hard drive crashed and I reformatted and restored it but then it crashed again about a day or two later.
My Fix
The hard drive replacement was a breeze. It took about 1hour and after formatting the new drive and loading OS X Yosemite all I had to do was restore my files from my backup USB drive. The free hard drive replacement guide was easy to follow. Also it was a nice upgrade from my original 1TB drive to a 2TB. Over all I am extremely satisfied with how everything went.
My Advice
The only issue I encountered was after I completed the install my drive fan was running at max speed. Got on the web and found an app called iStat Menus. This app had a menu that enabled me to control the fan speed with no problem.
My Problem
Easy to do and very inexpensive way to get computer working
My Fix
Very well for a novice at this type of repair.
Great instructions. Could have used info on material to use in replacing the heat sensor to the HD. I used a silicon paste, but wasn't sure this was the right answer. Seems to work fine.
My Advice
For the HD heat sensor cable, I would recommend taking it off at the mother board. i damaged the connector at the HD end (one pin came loose in connector) and had to carefully replace it. Mother board cable connector is much more robust.
My Problem
My iMac's original 250 GB hard drive failed. Since it was a 2008 model, full repair at a service center would cost more than the computer was worth. Aside from the HD, it was in pristine condition & had an Intel processor that could handle the latest version of OSX (Yosemite), so I felt it still had some life in it. I bought a 2 TB drive from IFIXIT and installed it myself. I also upgraded the RAM while I was at it. I'm happy I did it!
My Fix
The repair went well. The overview video and step by step directions are extremely well done - clear & thorough, with tech notes that point out helpful little things that only a full time computer tech would know.
My Advice
I'm detail oriented by nature. Whenever I follow any kind of written or video instructions, I usually find things that could be presented better. You guys do such an impressive job that I have nothing to say but THANKS!
