iPhone XS Taptic Engine Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone XS Taptic Engine Assembly Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone XS Taptic Engine Assembly Replacement, Tape over any cracks: step 2, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement, Tape over any cracks: step 2, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement, Tape over any cracks: step 2, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. iPhone XS Taptic Engine Assembly Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone XS Taptic Engine Assembly Replacement: step 4, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 4, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 4, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone XS Taptic Engine Assembly Replacement: step 5, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 5, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 5, image 3 of 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone XS Taptic Engine Assembly Replacement: step 6, image 1 of 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  7. iPhone XS Taptic Engine Assembly Replacement: step 7, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 7, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  8. iPhone XS Taptic Engine Assembly Replacement: step 8, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 8, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 8, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone XS Taptic Engine Assembly Replacement: step 9, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 9, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 9, image 3 of 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  10. iPhone XS Taptic Engine Assembly Replacement, Screen information: step 10, image 1 of 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone XS Taptic Engine Assembly Replacement: step 11, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 11, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 11, image 3 of 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone XS Taptic Engine Assembly Replacement: step 12, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 12, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 12, image 3 of 3
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  13. iPhone XS Taptic Engine Assembly Replacement: step 13, image 1 of 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  14. iPhone XS Taptic Engine Assembly Replacement: step 14, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 14, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 14, image 3 of 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  15. iPhone XS Taptic Engine Assembly Replacement, Display Assembly: step 15, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement, Display Assembly: step 15, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Remove five screws securing the logic board connector bracket, of the following lengths:
    • Three 1.0 mm Y000 screws
    • One 1.3 mm Y000 screw
    • One 3.7 mm Phillips screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  16. iPhone XS Taptic Engine Assembly Replacement: step 16, image 1 of 1
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  17. iPhone XS Taptic Engine Assembly Replacement: step 17, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 17, image 2 of 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone XS Taptic Engine Assembly Replacement: step 18, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 18, image 2 of 2
    • Use a spudger or a fingernail to pry up and disconnect the front panel sensor assembly connector.
  19. iPhone XS Taptic Engine Assembly Replacement: step 19, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 19, image 2 of 2
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  20. iPhone XS Taptic Engine Assembly Replacement: step 20, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 20, image 2 of 2
    • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  21. iPhone XS Taptic Engine Assembly Replacement: step 21, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 21, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 21, image 3 of 3
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  22. iPhone XS Taptic Engine Assembly Replacement: step 22, image 1 of 1
  23. iPhone XS Taptic Engine Assembly Replacement, Lower Speaker: step 23, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement, Lower Speaker: step 23, image 2 of 2
    • Remove the five screws securing the two brackets below the Taptic Engine and main speaker:
    • One 1.0 mm tri-point Y000 screw
    • Two 1.3 mm Phillips screws
    • One 1.7 mm Phillips screw
    • One 1.8 mm Phillips screw
  24. iPhone XS Taptic Engine Assembly Replacement: step 24, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 24, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 24, image 3 of 3
    • The brackets are lightly adhered in place.
    • Gently lift to unstick and remove each bracket, being careful not to bend it.
    • If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
  25. iPhone XS Taptic Engine Assembly Replacement: step 25, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 25, image 2 of 2
    • Remove the 1.9 mm Phillips screw securing the speaker connector cover.
  26. iPhone XS Taptic Engine Assembly Replacement: step 26, image 1 of 1
    • Remove the speaker connector cover.
  27. iPhone XS Taptic Engine Assembly Replacement: step 27, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 27, image 2 of 2
    • Use the tip of a spudger to pry up and disconnect the speaker connector.
  28. iPhone XS Taptic Engine Assembly Replacement: step 28, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 28, image 2 of 2
    • When prying up the speaker, take care not to damage the speaker flex cable you just disconnected. If necessary, bend the cable toward the battery so the speaker has room to come out.
    • Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker slightly.
    • When reinstalling the speaker, check the position of the flex cable and make sure it doesn't get trapped underneath the speaker.
  29. iPhone XS Taptic Engine Assembly Replacement: step 29, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 29, image 2 of 2
    • While prying up the speaker, use tweezers to peel away the plastic bumper strip from the top edge of the speaker.
    • If necessary, apply a little heat to soften the adhesive and make the bumper strip easier to separate.
  30. iPhone XS Taptic Engine Assembly Replacement: step 30, image 1 of 3 iPhone XS Taptic Engine Assembly Replacement: step 30, image 2 of 3 iPhone XS Taptic Engine Assembly Replacement: step 30, image 3 of 3
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
  31. iPhone XS Taptic Engine Assembly Replacement: step 31, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 31, image 2 of 2
    • Remove the speaker.
    • The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
    • To help protect against water and dust intrusion, replace the adhesive gasket during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
  32. iPhone XS Taptic Engine Assembly Replacement, Taptic Engine Assembly: step 32, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement, Taptic Engine Assembly: step 32, image 2 of 2
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
  33. iPhone XS Taptic Engine Assembly Replacement: step 33, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 33, image 2 of 2
    • Remove the two 1.9 mm Phillips screws securing the Taptic Engine.
  34. iPhone XS Taptic Engine Assembly Replacement: step 34, image 1 of 2 iPhone XS Taptic Engine Assembly Replacement: step 34, image 2 of 2
    • Grasp the plastic bumper strip and carefully lift it over the speaker connector.
  35. iPhone XS Taptic Engine Assembly Replacement: step 35, image 1 of 1
    • Remove the Taptic Engine assembly.
Jeff Suovanen
428,530 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 10
All Time: 79
