iPhone 8 Plus Rear-Facing Cameras Replacement
  1. iPhone 8 Plus Rear-Facing Cameras Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 8 Plus Rear-Facing Cameras Replacement, Tape over any cracks: step 2, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement, Tape over any cracks: step 2, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement, Tape over any cracks: step 2, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 8 Plus Rear-Facing Cameras Replacement: step 4, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 4, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 4, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 8 Plus Rear-Facing Cameras Replacement: step 5, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 5, image 2 of 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 8 Plus Rear-Facing Cameras Replacement: step 6, image 1 of 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 8 Plus Rear-Facing Cameras Replacement: step 7, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 7, image 2 of 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 8 Plus Rear-Facing Cameras Replacement: step 8, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 8, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 8, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 8 Plus Rear-Facing Cameras Replacement: step 9, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 9, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 9, image 3 of 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
  10. iPhone 8 Plus Rear-Facing Cameras Replacement, Screen information: step 10, image 1 of 1
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  11. iPhone 8 Plus Rear-Facing Cameras Replacement: step 11, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 11, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 11, image 3 of 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 8 Plus Rear-Facing Cameras Replacement: step 12, image 1 of 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  13. iPhone 8 Plus Rear-Facing Cameras Replacement: step 13, image 1 of 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  14. iPhone 8 Plus Rear-Facing Cameras Replacement: step 14, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 14, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 14, image 3 of 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  15. iPhone 8 Plus Rear-Facing Cameras Replacement: step 15, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 15, image 2 of 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  16. iPhone 8 Plus Rear-Facing Cameras Replacement: step 16, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 16, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 16, image 3 of 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  17. iPhone 8 Plus Rear-Facing Cameras Replacement, Battery Disconnection: step 17, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement, Battery Disconnection: step 17, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  18. iPhone 8 Plus Rear-Facing Cameras Replacement: step 18, image 1 of 1
    • Remove the lower display cable bracket.
  19. iPhone 8 Plus Rear-Facing Cameras Replacement: step 19, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 19, image 2 of 2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 8 Plus Rear-Facing Cameras Replacement, Display Assembly: step 20, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement, Display Assembly: step 20, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  21. iPhone 8 Plus Rear-Facing Cameras Replacement: step 21, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 21, image 2 of 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
  22. iPhone 8 Plus Rear-Facing Cameras Replacement: step 22, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 22, image 2 of 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
  23. iPhone 8 Plus Rear-Facing Cameras Replacement: step 23, image 1 of 1
    • Remove the bracket covering the front panel sensor assembly connector.
  24. iPhone 8 Plus Rear-Facing Cameras Replacement: step 24, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 24, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
  25. iPhone 8 Plus Rear-Facing Cameras Replacement: step 25, image 1 of 1
  26. iPhone 8 Plus Rear-Facing Cameras Replacement, Rear-Facing Cameras: step 26, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement, Rear-Facing Cameras: step 26, image 2 of 2
    • Remove the two Y000 screws securing the rear camera connector cover bracket:
    • One 1.4 mm screw
    • One 1.4 mm (nonferrous) screw
    • This screw tends to not be attracted to a magnetized screwdriver. Make sure to reinstall it in the correct place—a magnetized screw may interfere with the compass.
  27. iPhone 8 Plus Rear-Facing Cameras Replacement: step 27, image 1 of 1
    • Remove the bracket.
  28. iPhone 8 Plus Rear-Facing Cameras Replacement: step 28, image 1 of 2 iPhone 8 Plus Rear-Facing Cameras Replacement: step 28, image 2 of 2
    Standoff Screwdriver for iPhones
    $5.49
    Buy
    • Remove the two screws securing the rear camera module cover plate:
    • One 1.8 mm Phillips screw
    • One 2.7 mm (nonferrous) standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage nearby components.
  29. iPhone 8 Plus Rear-Facing Cameras Replacement: step 29, image 1 of 1
    • Remove the cover plate from the rear camera module.
  30. iPhone 8 Plus Rear-Facing Cameras Replacement: step 30, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 30, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 30, image 3 of 3
    • Use an iFixit opening tool or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  31. iPhone 8 Plus Rear-Facing Cameras Replacement: step 31, image 1 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 31, image 2 of 3 iPhone 8 Plus Rear-Facing Cameras Replacement: step 31, image 3 of 3
    • Use the flat end of a spudger to pry up the rear-facing camera assembly from the top edge of the iPhone.
    • If you have trouble, switch to the point of your spudger and lever the camera out from its top right corner.
  32. iPhone 8 Plus Rear-Facing Cameras Replacement: step 32, image 1 of 1
    • Remove the rear-facing camera assembly.
Jeff Suovanen
428,539 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,199 Guides authored
Past 24 Hours: 8
Past 7 Days: 58
Past 30 Days: 328
All Time: 43,350
