iPhone 7 Plus LCD and Digitizer Replacement
  1. iPhone 7 Plus LCD and Digitizer Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: step 2, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: step 2, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: step 2, image 3 of 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 7 Plus LCD and Digitizer Replacement, Opening Procedure: step 3, image 1 of 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  4. iPhone 7 Plus LCD and Digitizer Replacement: step 4, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 4, image 2 of 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 7 Plus LCD and Digitizer Replacement: step 5, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 5, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 5, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
  6. iPhone 7 Plus LCD and Digitizer Replacement: step 6, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 6, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 6, image 3 of 3
    • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
    • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  7. iPhone 7 Plus LCD and Digitizer Replacement: step 7, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 7, image 2 of 2
    • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
    • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
  8. iPhone 7 Plus LCD and Digitizer Replacement: step 8, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 8, image 2 of 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 Plus LCD and Digitizer Replacement: step 9, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 9, image 2 of 2
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 Plus LCD and Digitizer Replacement: step 10, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 10, image 2 of 2
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  11. iPhone 7 Plus LCD and Digitizer Replacement: step 11, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 11, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 11, image 3 of 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  12. iPhone 7 Plus LCD and Digitizer Replacement, Battery Disconnection: step 12, image 1 of 1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  13. iPhone 7 Plus LCD and Digitizer Replacement: step 13, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 13, image 2 of 2
    • Remove the lower display cable bracket.
  14. iPhone 7 Plus LCD and Digitizer Replacement: step 14, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 14, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 14, image 3 of 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: step 15, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: step 15, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: step 15, image 3 of 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. iPhone 7 Plus LCD and Digitizer Replacement: step 16, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 16, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 16, image 3 of 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  17. iPhone 7 Plus LCD and Digitizer Replacement: step 17, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 17, image 2 of 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. iPhone 7 Plus LCD and Digitizer Replacement: step 18, image 1 of 1
  19. iPhone 7 Plus LCD and Digitizer Replacement, Earpiece Speaker: step 19, image 1 of 1
    • Remove the five Phillips screws securing the earpiece speaker bracket:
    • Two 1.8 mm screws
    • One 2.3 mm screw
    • One 2.4 mm screw
    • One 2.8 mm screw
  20. iPhone 7 Plus LCD and Digitizer Replacement: step 20, image 1 of 1
    • Remove the earpiece speaker bracket.
  21. iPhone 7 Plus LCD and Digitizer Replacement: step 21, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 21, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 21, image 3 of 3
    • Use the flat end of a spudger to lift the front-facing camera from its housing.
    • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
  22. iPhone 7 Plus LCD and Digitizer Replacement: step 22, image 1 of 1
    • Remove the earpiece speaker.
    • Don't touch the four spring contacts with your fingers—your skin oils may cause a malfunction. If accidentally touched, clean the contacts gently with isopropyl alcohol (90% or higher).
  23. iPhone 7 Plus LCD and Digitizer Replacement, Front Camera and Sensor Cable: step 23, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement, Front Camera and Sensor Cable: step 23, image 2 of 2
    • Gently fold the camera and attached ribbon cable toward the bottom of the iPhone to allow access to the components underneath.
  24. iPhone 7 Plus LCD and Digitizer Replacement: step 24, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 24, image 2 of 2
    • The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
    • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
  25. iPhone 7 Plus LCD and Digitizer Replacement: step 25, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 25, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 25, image 3 of 3
    • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
  26. iPhone 7 Plus LCD and Digitizer Replacement: step 26, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 26, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 26, image 3 of 3
    • Insert the sharp edge of an iFixit opening tool underneath the camera assembly's flex cable, on the opposite side from the front-facing camera.
    • If necessary, use an iOpener or hair dryer to heat the top portion of the display and soften the adhesive securing the flex cable.
    • Pry up to separate the edge of the flex cable from the back of the display.
  27. iPhone 7 Plus LCD and Digitizer Replacement: step 27, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 27, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 27, image 3 of 3
    • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
    • Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
  28. iPhone 7 Plus LCD and Digitizer Replacement: step 28, image 1 of 1
    • Continue using your spudger to carefully separate the last of the flex cable from the back of the display.
  29. iPhone 7 Plus LCD and Digitizer Replacement: step 29, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 29, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 29, image 3 of 3
    • Remove the front camera and sensor cable assembly.
    • A piece of black double-sided insulating tape lies between the display and three rows of copper contacts on the back of the camera/sensor cable. It may remain stuck to the display, or it may come off with the cable.
    • When reassembling, verify the tape is in place, or else cover the contacts on the back of the cable with an appropriate tape, such as Kapton tape.
  30. iPhone 7 Plus LCD and Digitizer Replacement, Home/Touch ID Sensor: step 30, image 1 of 1
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.1 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
  31. iPhone 7 Plus LCD and Digitizer Replacement: step 31, image 1 of 1
    • Remove the bracket that secures the home/Touch ID sensor.
  32. iPhone 7 Plus LCD and Digitizer Replacement: step 32, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 32, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 32, image 3 of 3
  33. iPhone 7 Plus LCD and Digitizer Replacement: step 33, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 33, image 2 of 2
    • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
    • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
    • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
    • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
  34. iPhone 7 Plus LCD and Digitizer Replacement: step 34, image 1 of 1
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
  35. iPhone 7 Plus LCD and Digitizer Replacement: step 35, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 35, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 35, image 3 of 3
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  36. iPhone 7 Plus LCD and Digitizer Replacement: step 36, image 1 of 1
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display.
    • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    • Follow this guide to install replacement display adhesive on your screen.
  37. iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: step 37, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: step 37, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: step 37, image 3 of 3
    • Peel back the upper, rectangular portion of the LCD shield plate sticker to separate it from the flex cable underneath.
    • You don't need to remove the sticker completely unless you intend to replace it.
  38. iPhone 7 Plus LCD and Digitizer Replacement: step 38, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 38, image 2 of 2
    • Use a Y000 driver to remove three 1.1 mm screws from one side of the display EMI shield.
    • If you have trouble loosening these screws, press the driver harder onto the screw as you turn it. If necessary, use the flat edge of your spudger to brace each display clip from behind so you can apply more pressure to the screws, without bending the clips.
  39. iPhone 7 Plus LCD and Digitizer Replacement: step 39, image 1 of 1
    • Use a Y000 driver to remove two more 1.1 mm screws from the other side of the EMI shield.
  40. iPhone 7 Plus LCD and Digitizer Replacement: step 40, image 1 of 1
    • Remove the 1.8 mm Phillips screw securing the EMI shield near the bottom of the display.
  41. iPhone 7 Plus LCD and Digitizer Replacement: step 41, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 41, image 2 of 2
    • Lift the LCD shield plate while pressing down on the flex cable it surrounds.
    • Feed the flex cable through the cutout in the LCD shield plate, being careful not to snag it.
  42. iPhone 7 Plus LCD and Digitizer Replacement: step 42, image 1 of 1
    • Remove the LCD shield plate.
  43. iPhone 7 Plus LCD and Digitizer Replacement: step 43, image 1 of 1
    • Only the LCD and digitizer assembly remains.
Jeff Suovanen
428,424 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,187 Guides authored
Past 24 Hours: 13
Past 7 Days: 138
Past 30 Days: 6,430
All Time: 199,833
