iPhone 6s Screen Replacement
  1. iPhone 6s Screen Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
    Ask FixBot
  2. iPhone 6s Screen Replacement, Tape over the display: step 2, image 1 of 3 iPhone 6s Screen Replacement, Tape over the display: step 2, image 2 of 3 iPhone 6s Screen Replacement, Tape over the display: step 2, image 3 of 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
    Ask FixBot
  3. iPhone 6s Screen Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 6s Screen Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 6s Screen Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Ask FixBot
  4. iPhone 6s Screen Replacement: step 4, image 1 of 3 iPhone 6s Screen Replacement: step 4, image 2 of 3 iPhone 6s Screen Replacement: step 4, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Ask FixBot
  5. iPhone 6s Screen Replacement, Opening Procedure: step 5, image 1 of 1
    Clampy - Anti-Clamp
    $24.95
    Buy
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
    Ask FixBot
  6. iPhone 6s Screen Replacement: step 6, image 1 of 1
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Ask FixBot
  7. iPhone 6s Screen Replacement: step 7, image 1 of 2 iPhone 6s Screen Replacement: step 7, image 2 of 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
    Ask FixBot
  8. iPhone 6s Screen Replacement: step 8, image 1 of 2 iPhone 6s Screen Replacement: step 8, image 2 of 2
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
    Ask FixBot
  9. iPhone 6s Screen Replacement: step 9, image 1 of 2 iPhone 6s Screen Replacement: step 9, image 2 of 2
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
    Ask FixBot
  10. iPhone 6s Screen Replacement: step 10, image 1 of 2 iPhone 6s Screen Replacement: step 10, image 2 of 2
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
    Ask FixBot
  11. iPhone 6s Screen Replacement: step 11, image 1 of 2 iPhone 6s Screen Replacement: step 11, image 2 of 2
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
    Ask FixBot
  12. iPhone 6s Screen Replacement: step 12, image 1 of 2 iPhone 6s Screen Replacement: step 12, image 2 of 2
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
    Ask FixBot
  13. iPhone 6s Screen Replacement: step 13, image 1 of 2 iPhone 6s Screen Replacement: step 13, image 2 of 2
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
    Ask FixBot
  14. iPhone 6s Screen Replacement: step 14, image 1 of 2 iPhone 6s Screen Replacement: step 14, image 2 of 2
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
    Ask FixBot
  15. iPhone 6s Screen Replacement: step 15, image 1 of 3 iPhone 6s Screen Replacement: step 15, image 2 of 3 iPhone 6s Screen Replacement: step 15, image 3 of 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
    • During reassembly, the camera end of the screen body needs to hook under the edge of the body. The hooks of the screen frame need to be under the rim of the main body and snugged toward the camera end to easily close the cover and have it properly clip.
    • These hooks are not really a proper hinge but clasps that need to be under the rim of the main phone frame/edge!! This way the screen easily will return to its closed state nicely gently snapping into place.
    • During reassembly, reverse order for getting the screen clipped back in means pressing along the right side top to bottom corner. Then the left.
    Ask FixBot
  16. iPhone 6s Screen Replacement, Battery Connector: step 16, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    Ask FixBot
  17. iPhone 6s Screen Replacement: step 17, image 1 of 2 iPhone 6s Screen Replacement: step 17, image 2 of 2
    • Remove the battery connector bracket from the iPhone.
    Ask FixBot
  18. iPhone 6s Screen Replacement: step 18, image 1 of 3 iPhone 6s Screen Replacement: step 18, image 2 of 3 iPhone 6s Screen Replacement: step 18, image 3 of 3
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
    Ask FixBot
  19. iPhone 6s Screen Replacement: step 19, image 1 of 2 iPhone 6s Screen Replacement: step 19, image 2 of 2
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
    Ask FixBot
  20. iPhone 6s Screen Replacement, Unfasten the display cable bracket: step 20, image 1 of 1
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
    Ask FixBot
  21. iPhone 6s Screen Replacement: step 21, image 1 of 2 iPhone 6s Screen Replacement: step 21, image 2 of 2
    • Remove the display cable bracket.
    Ask FixBot
  22. iPhone 6s Screen Replacement: step 22, image 1 of 2 iPhone 6s Screen Replacement: step 22, image 2 of 2
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
    Ask FixBot
  23. iPhone 6s Screen Replacement: step 23, image 1 of 2 iPhone 6s Screen Replacement: step 23, image 2 of 2
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    Ask FixBot
  24. iPhone 6s Screen Replacement: step 24, image 1 of 2 iPhone 6s Screen Replacement: step 24, image 2 of 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
    Ask FixBot
  25. iPhone 6s Screen Replacement: step 25, image 1 of 1
    Ask FixBot
  26. iPhone 6s Screen Replacement, Home Button Assembly: step 26, image 1 of 1
    • Remove the three 1.7 mm Phillips screws securing the home button bracket.
    • Do not over-tighten these screws as these can damage the front of the display.
    Ask FixBot
  27. iPhone 6s Screen Replacement: step 27, image 1 of 3 iPhone 6s Screen Replacement: step 27, image 2 of 3 iPhone 6s Screen Replacement: step 27, image 3 of 3
    • Lift the lower edge of the home button bracket until it clears the small peg on the right side.
    • Slide the bracket out from under the EMI shield to remove it.
    Ask FixBot
  28. iPhone 6s Screen Replacement: step 28, image 1 of 2 iPhone 6s Screen Replacement: step 28, image 2 of 2
    • Use a spudger to disconnect the home button connector by popping it out of its socket on the back of the display panel.
    Ask FixBot
  29. iPhone 6s Screen Replacement: step 29, image 1 of 2 iPhone 6s Screen Replacement: step 29, image 2 of 2
    iOpener
    $24.95
    Buy
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
    Ask FixBot
  30. iPhone 6s Screen Replacement: step 30, image 1 of 2 iPhone 6s Screen Replacement: step 30, image 2 of 2
    • Use the pointed tip of a spudger to carefully separate the home button flex cable from the back of the display panel.
    Ask FixBot
  31. iPhone 6s Screen Replacement: step 31, image 1 of 2 iPhone 6s Screen Replacement: step 31, image 2 of 2
    • Remove the home button assembly.
    Ask FixBot
  32. iPhone 6s Screen Replacement, Screen: step 32, image 1 of 1
    • Only the screen remains.
    Ask FixBot
1411 other people completed this guide.
Jeff Suovanen
453,113 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
26,572 Guides authored
139 Guide Comments
Muito bom. Já aprendi muito consultando os tutoriais da IFIXIT. Parabéns.
Eder Macario - Reply Share
Solution worked very well - a couple of comments: 1. With a cracked screen the suction cup doesn't hold very well, I was nevertheless able to get the screen corner off with some heavy prying above the headphone jack as suggested in step 4. 2. In the replacement part I received, the order of the digitizer and camera cables was reversed, I had to tuck the digitizer cable back under the camera cable to get them down in the correct order. Great pictures and guide from ifixit.
stread777 - Reply Share
Agree with both points. The guide is also missing steps (or mention of) moving the camera/sensor/etc to the new digitizer. I didn't think about it until I wondered why the old screen had 3 cables and the new one only had 2.
nerdatheart - Reply Share
Thanks for the tip, I had the same issue with the suction cup not working on the cracked screen. Applying clear packaging tape over the screen helped but it still didn't come apart. Ended up using a blow dryer on the highest setting to help melt the adhesive around the bottom of the phone (being careful to not let it heat up too long) which eventually made it possible to wedge the spudge inside.
The guide and photos were great along with the replacement part from iFixit. Probably the easiest screen replacement I've done so far.
gotchay - Reply Share
Try putting packing tape in the center of the screen. This will keep the glass chunks in and the suction cup will stick to it.
Michael St. Hilaire - Reply Share
Past 24 Hours: 41
Past 7 Days: 253
Past 30 Days: 913
All Time: 1,033,603
