Introduction
The Lightning connector, headphone jack, and cellular antenna are on a single assembly and must be removed and replaced together.
You can also use this guide to replace the microphone gasket.
Video Overview
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
Tool used on this step:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following two screws securing the metal battery connector bracket to the logic board:
One 1.8 mm Phillips screw
One 1.6 mm Phillips screw
Remove the metal battery connector bracket from the iPhone.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following screws securing the front panel assembly cable bracket to the logic board:
Two 1.2 mm Phillips screws
Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
Front-facing camera and sensor cable
LCD cable
Digitizer cable
Remove the front panel assembly from the rear case.
Use the point of a spudger to pry up and disconnect the antenna cable from the logic board.
Slide the point of a spudger underneath the spring contact flex cable below the battery and gently loosen it from the speaker enclosure.
Use the flat end of a spudger to pry up and loosen the speaker enclosure from the rear case.
Pull the speaker enclosure out of its recess.
Remove the small double-sided metal washer on the speaker enclosure and transfer it to the replacement part.
Remove the following screws securing the Lightning connector assembly to the rear case:
One 2.9 mm Phillips screw
One 1.5 mm Phillips screw
Two 3.3 mm Phillips screws
Use the opening tool to pry up and disconnect the Lightning connector cable connector from its socket on the logic board.
Flip the phone face up, heat an iOpener, and apply it to the right edge of the phone for a minute.
Slide an opening pick underneath the Lightning connector flex cable to loosen it from the logic board and the rear case.
Use the flat end of a spudger to loosen the rest of the Lightning connector assembly from the rear case.
Angle the Lightning connector assembly and pull it out of its recess.
Remove the four metal washers and set them aside for reassembly.
