iPhone 13 Screen Replacement
    1. iPhone 13 Screen Replacement, Remove the pentalobe screws: step 1, image 1 of 1
      • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 13 Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 13 Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 13 Screen Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 13 Screen Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 13 Screen Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 13 Screen Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 13 Screen Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 13 Screen Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 13 Screen Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    3. iPhone 13 Screen Replacement: step 5, image 1 of 3 iPhone 13 Screen Replacement: step 5, image 2 of 3 iPhone 13 Screen Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPhone 13 Screen Replacement: step 6, image 1 of 2 iPhone 13 Screen Replacement: step 6, image 2 of 2
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    5. iPhone 13 Screen Replacement, Heat the bottom edge: step 7, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch. This softens the adhesive securing it.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    6. iPhone 13 Screen Replacement, Apply a suction cup: step 8, image 1 of 2 iPhone 13 Screen Replacement, Apply a suction cup: step 8, image 2 of 2
      • If you're using a single suction handle, apply it to the bottom edge of the screen.
      Ask FixBot
    7. iPhone 13 Screen Replacement, Screen information: step 9, image 1 of 3 iPhone 13 Screen Replacement, Screen information: step 9, image 2 of 3 iPhone 13 Screen Replacement, Screen information: step 9, image 3 of 3
      • To avoid damaging your screen in the next step, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    8. iPhone 13 Screen Replacement, Lift the screen slightly: step 10, image 1 of 3 iPhone 13 Screen Replacement, Lift the screen slightly: step 10, image 2 of 3 iPhone 13 Screen Replacement, Lift the screen slightly: step 10, image 3 of 3
      • Pull up on the suction handle with firm, constant pressure to create a slight gap under the screen’s plastic bezel.
      • The adhesive holding the screen in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
      • Insert an opening pick into the gap.
      • Remember to insert the opening pick under the thick plastic bezel to avoid damaging your screen.
      Ask FixBot
    9. iPhone 13 Screen Replacement, Heat the right edge: step 11, image 1 of 2 iPhone 13 Screen Replacement, Heat the right edge: step 11, image 2 of 2
      • Heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    10. iPhone 13 Screen Replacement, Separate the right adhesive: step 12, image 1 of 3 iPhone 13 Screen Replacement, Separate the right adhesive: step 12, image 2 of 3 iPhone 13 Screen Replacement, Separate the right adhesive: step 12, image 3 of 3
      • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
      • Continue sliding up the right edge of the iPhone until you reach the top right corner.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Leave the pick in the top right corner before continuing.
      Ask FixBot
    11. iPhone 13 Screen Replacement: step 13, image 1 of 1
      • Heat the top edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    12. iPhone 13 Screen Replacement: step 14, image 1 of 3 iPhone 13 Screen Replacement: step 14, image 2 of 3 iPhone 13 Screen Replacement: step 14, image 3 of 3
      • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the top sensors.
      • Leave the pick in the top left corner before continuing.
      Ask FixBot
    13. iPhone 13 Screen Replacement, Heat the left edge: step 15, image 1 of 2 iPhone 13 Screen Replacement, Heat the left edge: step 15, image 2 of 2
      • Heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    14. iPhone 13 Screen Replacement, Separate the left adhesive: step 16, image 1 of 3 iPhone 13 Screen Replacement, Separate the left adhesive: step 16, image 2 of 3 iPhone 13 Screen Replacement, Separate the left adhesive: step 16, image 3 of 3
      • There are delicate cables along the left edge of your iPhone. Don't insert your pick deeper than 2 mm here, as you may damage the cables.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    15. iPhone 13 Screen Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 13 Screen Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 13 Screen Replacement, Open the iPhone: step 17, image 3 of 3
      • If you haven't removed your suction handle, remove it now.
      • Rotate your iPhone so the right edge faces you.
      • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone 13 Screen Replacement, Unscrew the battery and display connector cover: step 18, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips screwdriver to remove the three 1.3 mm screws securing the battery and display connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    2. iPhone 13 Screen Replacement, Remove the battery and display connector cover: step 19, image 1 of 1
      • Remove the cover.
      Ask FixBot
    3. iPhone 13 Screen Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 13 Screen Replacement, Disconnect the battery: step 20, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    1. iPhone 13 Screen Replacement, Disconnect the display cable: step 21, image 1 of 2 iPhone 13 Screen Replacement, Disconnect the display cable: step 21, image 2 of 2
      • Use a spudger or a fingernail to disconnect the display cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. iPhone 13 Screen Replacement, Unscrew the front sensor connector cover: step 22, image 1 of 1
      • Remove three screws securing the front sensor connector cover:
      • One 1.7 mm Phillips screw
      • One 1.3 mm Phillips screw
      • One 1.8 mm Y000 screw
      Ask FixBot
    3. iPhone 13 Screen Replacement, Remove the front sensor connector cover: step 23, image 1 of 2 iPhone 13 Screen Replacement, Remove the front sensor connector cover: step 23, image 2 of 2
      • Swing the cover up from the center of the phone until the small clip by the edge of the phone unhooks.
      Ask FixBot
    4. iPhone 13 Screen Replacement: step 24, image 1 of 2 iPhone 13 Screen Replacement: step 24, image 2 of 2
      • Remove the cover.
      • During reassembly, insert the clip on the left edge into its slot first, then hinge the rest of the cover into place.
      Ask FixBot
    5. iPhone 13 Screen Replacement, Disconnect the front sensors: step 25, image 1 of 2 iPhone 13 Screen Replacement, Disconnect the front sensors: step 25, image 2 of 2
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      Ask FixBot
    6. iPhone 13 Screen Replacement, Remove the screen: step 26, image 1 of 2 iPhone 13 Screen Replacement, Remove the screen: step 26, image 2 of 2
      Ask FixBot
    7. iPhone 13 Screen Replacement, Unfasten the front sensor bracket: step 27, image 1 of 1
      • The remaining steps demonstrate how to transfer the front sensor assembly to a new screen. If your replacement screen comes with the assembly pre-installed, skip these steps.
      • Use a Y000 screwdriver to remove the three 1.4 mm-long screws securing the sensor assembly bracket.
      Ask FixBot
    8. iPhone 13 Screen Replacement, Remove the front sensor bracket: step 28, image 1 of 2 iPhone 13 Screen Replacement, Remove the front sensor bracket: step 28, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
      Ask FixBot
    9. iPhone 13 Screen Replacement, Heat the front sensor assembly: step 29, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
      Ask FixBot
    10. iPhone 13 Screen Replacement, Disconnect the ambient light sensor: step 30, image 1 of 2 iPhone 13 Screen Replacement, Disconnect the ambient light sensor: step 30, image 2 of 2
      • Insert an opening pick between the ambient light sensor and its recess in the screen.
      • Pry up with the pick to separate the ambient light sensor from the screen.
      Ask FixBot
    11. iPhone 13 Screen Replacement, Disconnect the proximity sensor: step 31, image 1 of 2 iPhone 13 Screen Replacement, Disconnect the proximity sensor: step 31, image 2 of 2
      • Insert an opening pick between the proximity sensor and its recess in the screen.
      • Pry up with the pick to separate the proximity sensor from the screen.
      Ask FixBot
    12. iPhone 13 Screen Replacement, Reposition the proximity sensor: step 32, image 1 of 2 iPhone 13 Screen Replacement, Reposition the proximity sensor: step 32, image 2 of 2
      • Use tweezers, or your fingers, to move the proximity sensor cable away from the screen.
      Ask FixBot
    13. iPhone 13 Screen Replacement, Disconnect the microphone: step 33, image 1 of 3 iPhone 13 Screen Replacement, Disconnect the microphone: step 33, image 2 of 3 iPhone 13 Screen Replacement, Disconnect the microphone: step 33, image 3 of 3
      • Insert an opening pick under the microphone cable, close to the microphone (the metal rectangle).
      • Slide the opening pick around the perimeter of the microphone to separate its adhesive.
      Ask FixBot
    14. iPhone 13 Screen Replacement, Remove the front sensor assembly: step 34, image 1 of 3 iPhone 13 Screen Replacement, Remove the front sensor assembly: step 34, image 2 of 3 iPhone 13 Screen Replacement, Remove the front sensor assembly: step 34, image 3 of 3
      • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
      • Insert an opening pick under the left side of the front sensor assembly.
      • Slide the pick under the assembly to separate it from the frame.
      Ask FixBot
    15. iPhone 13 Screen Replacement: step 35, image 1 of 2 iPhone 13 Screen Replacement: step 35, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the front sensor assembly.
      • When transferring the assembly to a new screen, follow these instructions:
      • Connect the sensors to their slots in the frame to help align the main section of the assembly.
      • Use Tesa tape to re-adhere any sections of the assembly that are no longer sticky.
      Ask FixBot
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Answers community for help.
110 other people completed this guide.
Kyle Smith
53,139 Reputation
124 Guides authored
17 Guide Comments
Complimenti per le istruzioni ben fatte ! Potrebbe essere utile ricevere ad ogni riparazione l’elenco dei pezzi di ricambio da acquistare con i relativi codici così da quantificare anche il costo della riparazione. Utile anche per non sbagliare l’acquisto. Ciao, Roberto
Roberto Garancini - Reply Share
Can we now change the display without FACEID issue?
kerozine84 - Reply Share
Yes. You can.
Louis Osborne - Reply Share
Is it possible to get the TrueTone function back with a Display Programming Device like a JC V1S?
Igor H - Reply Share
Ciao ottima spiegazione, però perché con la flat sensori collegata alla scheda madre il display è scuro invece se la scollego il display torna luminoso? Io ho utilizzato un oled della GX.
Il problema è il sensore della live che si è danneggiato oppure bisogna fare qualche programmazione?
leonardo.147 - Reply Share
Past 24 Hours: 265
Past 7 Days: 1,898
Past 30 Days: 8,645
All Time: 340,189
