Xbox Series X Motherboard Replacement
  1. Xbox Series X Motherboard Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X Motherboard Replacement, Uncover the back panel screws: step 1, image 2 of 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Motherboard Replacement: step 2, image 1 of 3 Xbox Series X Motherboard Replacement: step 2, image 2 of 3 Xbox Series X Motherboard Replacement: step 2, image 3 of 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Motherboard Replacement, Remove the back panel screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Motherboard Replacement, Unclip the back panel: step 4, image 1 of 3 Xbox Series X Motherboard Replacement, Unclip the back panel: step 4, image 2 of 3 Xbox Series X Motherboard Replacement, Unclip the back panel: step 4, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Motherboard Replacement: step 5, image 1 of 2 Xbox Series X Motherboard Replacement: step 5, image 2 of 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Motherboard Replacement, Remove the back panel: step 6, image 1 of 3 Xbox Series X Motherboard Replacement, Remove the back panel: step 6, image 2 of 3 Xbox Series X Motherboard Replacement, Remove the back panel: step 6, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Motherboard Replacement: step 7, image 1 of 3 Xbox Series X Motherboard Replacement: step 7, image 2 of 3 Xbox Series X Motherboard Replacement: step 7, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Motherboard Replacement, Remove the fan screws: step 8, image 1 of 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X Motherboard Replacement, Disconnect the fan cable: step 9, image 1 of 3 Xbox Series X Motherboard Replacement, Disconnect the fan cable: step 9, image 2 of 3 Xbox Series X Motherboard Replacement, Disconnect the fan cable: step 9, image 3 of 3
    Buy
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X Motherboard Replacement, Remove the fan: step 10, image 1 of 2 Xbox Series X Motherboard Replacement, Remove the fan: step 10, image 2 of 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X Motherboard Replacement, Unlatch the base: step 11, image 1 of 3 Xbox Series X Motherboard Replacement, Unlatch the base: step 11, image 2 of 3 Xbox Series X Motherboard Replacement, Unlatch the base: step 11, image 3 of 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Motherboard Replacement, Twist and remove the base: step 12, image 1 of 3 Xbox Series X Motherboard Replacement, Twist and remove the base: step 12, image 2 of 3 Xbox Series X Motherboard Replacement, Twist and remove the base: step 12, image 3 of 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X Motherboard Replacement, Remove the optical drive screws: step 13, image 1 of 2 Xbox Series X Motherboard Replacement, Remove the optical drive screws: step 13, image 2 of 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Motherboard Replacement, Remove the vibration isolator: step 14, image 1 of 3 Xbox Series X Motherboard Replacement, Remove the vibration isolator: step 14, image 2 of 3 Xbox Series X Motherboard Replacement, Remove the vibration isolator: step 14, image 3 of 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Motherboard Replacement, Disconnect the power and data cables: step 15, image 1 of 3 Xbox Series X Motherboard Replacement, Disconnect the power and data cables: step 15, image 2 of 3 Xbox Series X Motherboard Replacement, Disconnect the power and data cables: step 15, image 3 of 3
    Buy
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X Motherboard Replacement, Remove the optical drive: step 16, image 1 of 2 Xbox Series X Motherboard Replacement, Remove the optical drive: step 16, image 2 of 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Motherboard Replacement, Disconnect the USB port cable: step 17, image 1 of 3 Xbox Series X Motherboard Replacement, Disconnect the USB port cable: step 17, image 2 of 3 Xbox Series X Motherboard Replacement, Disconnect the USB port cable: step 17, image 3 of 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Motherboard Replacement: step 18, image 1 of 2 Xbox Series X Motherboard Replacement: step 18, image 2 of 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X Motherboard Replacement, Disconnect the power button cable: step 19, image 1 of 3 Xbox Series X Motherboard Replacement, Disconnect the power button cable: step 19, image 2 of 3 Xbox Series X Motherboard Replacement, Disconnect the power button cable: step 19, image 3 of 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X Motherboard Replacement, Remove the chassis screws: step 20, image 1 of 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Motherboard Replacement, Peel up the USB port cable: step 21, image 1 of 2 Xbox Series X Motherboard Replacement, Peel up the USB port cable: step 21, image 2 of 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X Motherboard Replacement, Remove the center chassis assembly: step 22, image 1 of 3 Xbox Series X Motherboard Replacement, Remove the center chassis assembly: step 22, image 2 of 3 Xbox Series X Motherboard Replacement, Remove the center chassis assembly: step 22, image 3 of 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Motherboard Replacement, Unlatch the chassis strap: step 23, image 1 of 3 Xbox Series X Motherboard Replacement, Unlatch the chassis strap: step 23, image 2 of 3 Xbox Series X Motherboard Replacement, Unlatch the chassis strap: step 23, image 3 of 3
    • Unlatch the chassis strap from the right side of the power supply.
  24. Xbox Series X Motherboard Replacement: step 24, image 1 of 3 Xbox Series X Motherboard Replacement: step 24, image 2 of 3 Xbox Series X Motherboard Replacement: step 24, image 3 of 3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  25. Xbox Series X Motherboard Replacement, Remove the power cable port: step 25, image 1 of 1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  26. Xbox Series X Motherboard Replacement: step 26, image 1 of 2 Xbox Series X Motherboard Replacement: step 26, image 2 of 2
    • Lift the power connector out of its recess in the chassis.
  27. Xbox Series X Motherboard Replacement, De-route the power cables: step 27, image 1 of 2 Xbox Series X Motherboard Replacement, De-route the power cables: step 27, image 2 of 2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Xbox Series X Motherboard Replacement: step 28, image 1 of 2 Xbox Series X Motherboard Replacement: step 28, image 2 of 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Xbox Series X Motherboard Replacement, Remove the corner cover: step 29, image 1 of 1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  30. Xbox Series X Motherboard Replacement: step 30, image 1 of 2 Xbox Series X Motherboard Replacement: step 30, image 2 of 2
    Buy
    • Your Xbox may not have this cover depending on the model.
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  31. Xbox Series X Motherboard Replacement, Remove the accessory antenna board: step 31, image 1 of 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  32. Xbox Series X Motherboard Replacement: step 32, image 1 of 3 Xbox Series X Motherboard Replacement: step 32, image 2 of 3 Xbox Series X Motherboard Replacement: step 32, image 3 of 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  33. Xbox Series X Motherboard Replacement, Remove the board shield: step 33, image 1 of 1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  34. Xbox Series X Motherboard Replacement: step 34, image 1 of 3 Xbox Series X Motherboard Replacement: step 34, image 2 of 3 Xbox Series X Motherboard Replacement: step 34, image 3 of 3
    • Lift up the board shield to remove it from the center chassis.
  35. Xbox Series X Motherboard Replacement, Remove the chassis strap: step 35, image 1 of 3 Xbox Series X Motherboard Replacement, Remove the chassis strap: step 35, image 2 of 3 Xbox Series X Motherboard Replacement, Remove the chassis strap: step 35, image 3 of 3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  36. Xbox Series X Motherboard Replacement: step 36, image 1 of 2 Xbox Series X Motherboard Replacement: step 36, image 2 of 2
    • Remove the chassis strap.
  37. Xbox Series X Motherboard Replacement, Disconnect the motherboard: step 37, image 1 of 3 Xbox Series X Motherboard Replacement, Disconnect the motherboard: step 37, image 2 of 3 Xbox Series X Motherboard Replacement, Disconnect the motherboard: step 37, image 3 of 3
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
  38. Xbox Series X Motherboard Replacement: step 38, image 1 of 3 Xbox Series X Motherboard Replacement: step 38, image 2 of 3 Xbox Series X Motherboard Replacement: step 38, image 3 of 3
    • Grip the base of the interconnect cable connector with your fingers.
    • Depress each side of the connector to unlock the cable locking tabs.
    • With the locking tabs depressed, grip the edges of the interconnect cable and pull it straight out of the connector to disconnect it.
    • For some versions of the Series X, the interconnect cables are held down by a single locking tab in the middle. If you have this version, gently push the locking tab in with your fingernail, grip the sides of the interconnect cable and pull it out.
    • With the locking tabs depressed correctly, the interconnect cable will slide out with very little force.
    • During reassembly, the interconnect cable should "snap" into place when fully inserted.
  39. Xbox Series X Motherboard Replacement, Remove the silver power supply screws: step 39, image 1 of 2 Xbox Series X Motherboard Replacement, Remove the silver power supply screws: step 39, image 2 of 2
    • Use a T8 Torx driver to remove the three 35 mm‑long silver screws from the power supply—leave the fourth black screw in place.
  40. Xbox Series X Motherboard Replacement, Remove the center chassis: step 40, image 1 of 3 Xbox Series X Motherboard Replacement, Remove the center chassis: step 40, image 2 of 3 Xbox Series X Motherboard Replacement, Remove the center chassis: step 40, image 3 of 3
    • Grip the edges of the center chassis (not the power supply) and lift it off of the motherboard and heatsink assembly, routing the interconnect cable through its cutout.
  41. Xbox Series X Motherboard Replacement, Pry off the SSD shield: step 41, image 1 of 3 Xbox Series X Motherboard Replacement, Pry off the SSD shield: step 41, image 2 of 3 Xbox Series X Motherboard Replacement, Pry off the SSD shield: step 41, image 3 of 3
    • The SSD shield has thermal pads on either side, so ensure these are kept as intact as possible during this procedure.
    • Use the flat end of a spudger to pry up the edges of the metal SSD shield.
    • Remove the SSD shield.
  42. Xbox Series X Motherboard Replacement, Remove the SSD screw: step 42, image 1 of 1
    • Use a T8 Torx driver to remove the 5.2 mm screw securing the SSD.
  43. Xbox Series X Motherboard Replacement, Remove the SSD: step 43, image 1 of 2 Xbox Series X Motherboard Replacement, Remove the SSD: step 43, image 2 of 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  44. Xbox Series X Motherboard Replacement, Remove the interconnect cable: step 44, image 1 of 3 Xbox Series X Motherboard Replacement, Remove the interconnect cable: step 44, image 2 of 3 Xbox Series X Motherboard Replacement, Remove the interconnect cable: step 44, image 3 of 3
    • If your interconnect cable has a locking tab in the middle, skip to the next step.
    • Remove the interconnect cable.
  45. Xbox Series X Motherboard Replacement: step 45, image 1 of 3 Xbox Series X Motherboard Replacement: step 45, image 2 of 3 Xbox Series X Motherboard Replacement: step 45, image 3 of 3
    • Pinch the locking tab on the interconnect cable on the motherboard and use the flat end of a spudger to disengage the clip.
    • Use your fingers to pull the connector straight up and out of its socket.
    • During reassembly, insert the #1—SOC side of interconnect cable connector into its socket so the locking tab is facing outward. Then, press down on the edges of the connector until it snaps into place.
  46. Xbox Series X Motherboard Replacement, Remove the metal shield: step 46, image 1 of 3 Xbox Series X Motherboard Replacement, Remove the metal shield: step 46, image 2 of 3 Xbox Series X Motherboard Replacement, Remove the metal shield: step 46, image 3 of 3
    • Be very careful not to damage any of the components around the metal shield.
    • Use the flat end of a spudger to pry up the edges of the large metal shield in the center of the motherboard.
  47. Xbox Series X Motherboard Replacement: step 47, image 1 of 2 Xbox Series X Motherboard Replacement: step 47, image 2 of 2
    • Remove the metal shield.
    • During reassembly, set the shield into place and push down firmly around the perimeter to secure the shield.
  48. Xbox Series X Motherboard Replacement, Remove the APU tension bracket: step 48, image 1 of 2 Xbox Series X Motherboard Replacement, Remove the APU tension bracket: step 48, image 2 of 2
    • Only loosen and tighten the APU tension bracket screws a few turns at a time in an "X" pattern. For example: top left → bottom right → top right → bottom left.
    • Use a T8 Torx driver to remove the four 12.3 mm‑long APU tension bracket screws.
  49. Xbox Series X Motherboard Replacement: step 49, image 1 of 2 Xbox Series X Motherboard Replacement: step 49, image 2 of 2
    • Don't move the APU bracket side to side, or you may damage the delicate surface‑mounted components underneath it. Only lift straight up.
    • Use your fingers to lift the APU bracket straight up and remove it.
    • During reassembly, set the bracket into place so the black pieces of plastic are facing the long edges of the motherboard—the piece of plastic with a circular hole (not oblong) should be closer to the interconnect cable socket. Use this photo as a reference.
  50. Xbox Series X Motherboard Replacement: step 50, image 1 of 3 Xbox Series X Motherboard Replacement: step 50, image 2 of 3 Xbox Series X Motherboard Replacement: step 50, image 3 of 3
    • Depending on the condition of the thermal paste and putty, the board may be bonded to the heatsink assembly. If you can't easily remove the board, use a spudger to gently lift the edges of the board to separate it.
    • Lift the motherboard straight up and off of the heatsink to remove it.
    • During reassembly, carefully place the board onto the heatsink with the APU facing down. Remember, there's exposed thermal paste on the bottom of the board, so use the alignment pegs to orient it correctly. If you have to reposition the board, it may smear the thermal paste.
  51. Xbox Series X Motherboard Replacement, Thermal putty replacement: step 51, image 1 of 2 Xbox Series X Motherboard Replacement, Thermal putty replacement: step 51, image 2 of 2
    • Check the condition of the thermal putty—it'll be on the heatsink and/or the motherboard.
    • If any pieces are damaged or dried out, follow the next four steps to remove and replace them.
    • If you're only replacing the thermal paste, skip to this step.
  52. Xbox Series X Motherboard Replacement: step 52, image 1 of 3 Xbox Series X Motherboard Replacement: step 52, image 2 of 3 Xbox Series X Motherboard Replacement: step 52, image 3 of 3
    • Use the flat end of a spudger to scrape off the damaged or deteriorated thermal pad.
    • Be careful around any small surface-mounted components that might be hidden under the thermal pad. Work slowly to avoid accidentally prying them off.
  53. Xbox Series X Motherboard Replacement: step 53, image 1 of 2 Xbox Series X Motherboard Replacement: step 53, image 2 of 2
    Cotton Swabs
    Buy
    • Use isopropyl alcohol (>90%) and a lint-free microfiber cloth to remove any thermal putty residue.
    • If you have to work near the small resistors, use cotton swabs instead.
  54. Xbox Series X Motherboard Replacement: step 54, image 1 of 2 Xbox Series X Motherboard Replacement: step 54, image 2 of 2
    • To prevent the thermal putty from sticking to your fingers, consider wearing nitrile gloves.
    • Grab a small piece of thermal putty. Refer to the size of the thermal pad you're replacing for how much you need.
  55. Xbox Series X Motherboard Replacement: step 55, image 1 of 2 Xbox Series X Motherboard Replacement: step 55, image 2 of 2
    • Roll the thermal putty into a ball.
    • Place the thermal putty where the damaged thermal pad was, making sure it's centered over the component—in this case a memory chip.
    • Optionally, you can use the flat end of a spudger (or an included applicator) to spread the thermal putty over the surface of the component.
    • When you reattach the heat sink, you'll compress the thermal putty and it'll spread the ball out.
  56. Xbox Series X Motherboard Replacement, Replace the thermal paste: step 56, image 1 of 2 Xbox Series X Motherboard Replacement, Replace the thermal paste: step 56, image 2 of 2
    Cotton Swabs
    Buy
    • Apply a few drops of isopropyl alcohol (>90%) to the processor and use a coffee filter or a lint-free cloth to wipe away any residue.
  57. Xbox Series X Motherboard Replacement: step 57, image 1 of 2 Xbox Series X Motherboard Replacement: step 57, image 2 of 2
    • Repeat the previous step for the thermal paste on the heat sink.
    • You can use a spudger to scrape off the thermal paste on the heat sink if it's too dried out.
  58. Xbox Series X Motherboard Replacement, Apply the thermal paste: step 58, image 1 of 2 Xbox Series X Motherboard Replacement, Apply the thermal paste: step 58, image 2 of 2
    • Apply a small bead of thermal paste to the center of the APU.
    • Follow this guide in reverse order starting with this step to reattach the heat sink. Placing the heat sink back on the processor will evenly spread the thermal paste (and thermal putty if applicable) and bond both parts together.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
28 other people completed this guide.
Spencer Day
162,713 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,166 Guides authored
6 Guide Comments
There are five completely unnecessary steps in this guide all centered around removing the PSU and the part under it that don't need to be done in order to remove the motherboard/heatsink. You can cut out steps 38, 39, 41, 42 and 43 on step 40 you only need to remove the three 35mm screws to complete the step. As long as you complete the rest of the guide the top comes away without issue.
Alex Weaver - Reply Share
Hi Alex! The guide has been updated and any unnecessary steps have been removed. Thank you for the helpful information!
Spencer Day - Share
Thanks....... I just had one apart and skipped those steps with no problems.
Alan Sears - Reply Share
If you replace the motherboard will the disk drive still work?
tomjeffrey20 - Reply Share
GREAT TUTORIAL! this worked !
JOHN MALPAS - Reply Share
Past 24 Hours: 39
Past 7 Days: 338
Past 30 Days: 1,718
All Time: 53,334
