Google Pixel 6a Screen Replacement
Video Overview
  1. Google Pixel 6a Screen Replacement, Safety Precautions: step 1, image 1 of 2 Google Pixel 6a Screen Replacement, Safety Precautions: step 1, image 2 of 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Ask FixBot
  2. Google Pixel 6a Screen Replacement, Screen removal information: step 2, image 1 of 2 Google Pixel 6a Screen Replacement, Screen removal information: step 2, image 2 of 2
    • Before starting your repair, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    Ask FixBot
  3. Google Pixel 6a Screen Replacement, Anti-Clamp instructions: step 3, image 1 of 3 Google Pixel 6a Screen Replacement, Anti-Clamp instructions: step 3, image 2 of 3 Google Pixel 6a Screen Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over the right edge of your phone.
    • Position the suction cups near the middle of the right edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Ask FixBot
  4. Google Pixel 6a Screen Replacement: step 4, image 1 of 3 Google Pixel 6a Screen Replacement: step 4, image 2 of 3 Google Pixel 6a Screen Replacement: step 4, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Ask FixBot
  5. Google Pixel 6a Screen Replacement: step 5, image 1 of 2 Google Pixel 6a Screen Replacement: step 5, image 2 of 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp so it lays on the right edge of the phone.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Ask FixBot
  6. Google Pixel 6a Screen Replacement, Heat the right edge: step 6, image 1 of 1
    • Heat an iOpener and apply it to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Ask FixBot
  7. Google Pixel 6a Screen Replacement, Insert an opening pick: step 7, image 1 of 3 Google Pixel 6a Screen Replacement, Insert an opening pick: step 7, image 2 of 3 Google Pixel 6a Screen Replacement, Insert an opening pick: step 7, image 3 of 3
    • Apply a suction cup to the screen, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the bezel and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Ask FixBot
  8. Google Pixel 6a Screen Replacement, Reposition the opening pick: step 8, image 1 of 3 Google Pixel 6a Screen Replacement, Reposition the opening pick: step 8, image 2 of 3 Google Pixel 6a Screen Replacement, Reposition the opening pick: step 8, image 3 of 3
    • While still applying suction, pivot the pick upwards to a steep angle.
    • Carefully push the pick in while prying to reposition the opening pick into the bezel seam.
    • Only insert the pick up to 3.5 mm to avoid damaging the internals.
    Ask FixBot
  9. Google Pixel 6a Screen Replacement, Release the right clips: step 9, image 1 of 3 Google Pixel 6a Screen Replacement, Release the right clips: step 9, image 2 of 3 Google Pixel 6a Screen Replacement, Release the right clips: step 9, image 3 of 3
    • Slide the pick along the right edge to release the plastic clips securing the bezel to the frame.
    • Position the pick at the top-right edge before moving to the next step.
    Ask FixBot
  10. Google Pixel 6a Screen Replacement, Release the top right clips: step 10, image 1 of 3 Google Pixel 6a Screen Replacement, Release the top right clips: step 10, image 2 of 3 Google Pixel 6a Screen Replacement, Release the top right clips: step 10, image 3 of 3
    • Rotate the opening pick around the top-right corner of the phone to release the clips.
    • Leave the opening pick in the top-right corner to prevent the clips from re-locking.
    • Only insert the pick up to 4 mm to avoid damaging the internals.
    Ask FixBot
  11. Google Pixel 6a Screen Replacement, Release the top clips: step 11, image 1 of 3 Google Pixel 6a Screen Replacement, Release the top clips: step 11, image 2 of 3 Google Pixel 6a Screen Replacement, Release the top clips: step 11, image 3 of 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the top edge to release the clips.
    • When slicing around the front camera, only insert the pick up to 3 mm to avoid damaging the lens.
    Ask FixBot
  12. Google Pixel 6a Screen Replacement, Release the top left clips: step 12, image 1 of 3 Google Pixel 6a Screen Replacement, Release the top left clips: step 12, image 2 of 3 Google Pixel 6a Screen Replacement, Release the top left clips: step 12, image 3 of 3
    • Rotate the opening pick around the top-left corner of the phone to release the clips.
    • Leave the opening pick in the top-left corner to prevent the clips from re-locking.
    Ask FixBot
  13. Google Pixel 6a Screen Replacement, Release the left clips: step 13, image 1 of 3 Google Pixel 6a Screen Replacement, Release the left clips: step 13, image 2 of 3 Google Pixel 6a Screen Replacement, Release the left clips: step 13, image 3 of 3
    • Slide the pick along the left edge to release the clips.
    • Only insert the pick up to 3 mm to avoid damaging the internals.
    • Repeat the rotating and sliding procedure for the remaining edge.
    • At this point, the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to release any remaining clips.
    Ask FixBot
  14. Google Pixel 6a Screen Replacement, Reposition the screen: step 14, image 1 of 3 Google Pixel 6a Screen Replacement, Reposition the screen: step 14, image 2 of 3 Google Pixel 6a Screen Replacement, Reposition the screen: step 14, image 3 of 3
    • Don't try to remove the screen all the way yet. It's still connected to the frame by a flex cable.
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    Ask FixBot
  15. Google Pixel 6a Screen Replacement, Remove the display cable bracket: step 15, image 1 of 3 Google Pixel 6a Screen Replacement, Remove the display cable bracket: step 15, image 2 of 3 Google Pixel 6a Screen Replacement, Remove the display cable bracket: step 15, image 3 of 3
    Buy
    • The display cable bracket is secured with metal clips.
    • Use tweezers to bend the bottom side of the bracket upwards, releasing the metal clip.
    • Remove the display cable bracket.
    • During reassembly, insert the top side of the bracket first before pressing down the other side. Failure to do so could result in sparks and logic board damage.
    Ask FixBot
  16. Google Pixel 6a Screen Replacement, Disconnect the display cable: step 16, image 1 of 3 Google Pixel 6a Screen Replacement, Disconnect the display cable: step 16, image 2 of 3 Google Pixel 6a Screen Replacement, Disconnect the display cable: step 16, image 3 of 3
    • Be very careful performing this step, as you risk damaging tiny components around the press connector.
    • Insert the tip of an opening pick under the bottom right edge of the display cable press connector, right above the nearby screw hole.
    • Pry up and disconnect the display cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  17. Google Pixel 6a Screen Replacement, Screen information: step 17, image 1 of 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Ask FixBot
  18. Google Pixel 6a Screen Replacement, Reassembly information: step 18, image 1 of 2 Google Pixel 6a Screen Replacement, Reassembly information: step 18, image 2 of 2
    • Remove the screen.
    • During reassembly:
    • If you replaced your screen, check the front-facing camera hole and the sensor cutout on your replacement screen, and remove any remaining liners.
    • Check your phone if the proximity sensor's rubber gasket is missing—it might be stuck to the back of your old screen. Replace it if necessary.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone.
    • Remember to reinstall the display cable bracket.
    • Follow this guide to replace the screen adhesive.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 6a Answers community for help.
238 other people completed this guide.
Alex Diaz-Kokaisl
245,332 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
31,535 Guides authored
102 Guide Comments
How do I glue the new screen to make it waterproof.
Brenda Holt - Reply Share
My screen replacement of my 6a was a success. Thank you IFixit :) Very good kit with good tutorial :)
fpoulin1 - Reply Share
Just replaced the screen and it is a GREAT REPLACEMENT. Only issue is the fingerprint reader isn't working. Issue is with google NOT this replacement screen. I haven't been able to find a solution. Even when trying to install google's "Install fingerprint calibration software". I have an appointment with "Ufixit" to see if they can resolve it. Google's tech said it isn't a common issue but just wanted to share my experience.
Also...Install steps only show how to take the screen off. Steps to install would be helpful because there are some tips to aligning/applying the adhesive that would be helpful to consumers.
Jon Holland - Reply Share
the new display's fringer sensor must be replaced with the same(old screen's).
Rahilkhan Pathan - Reply Share
Jon, the comment immediately above mine is incorrect. You do NOT need to replace the new fingerprint sensor with the old one. It's built into the screen. I don't know how you'd even do this. The iFixit page for the screen itself, as well as the instructions above, and so many commenters, all point out that the fingerprint sensor will need to be recalibrated after replacement. As others noted, make sure you've got the Pixel USB drivers installed and that Windows can see your phone. Do the screen replacement as described. Then go to the pixelrepair.withgoogle.com page, shut down the phone, reboot in fastboot mode and install the calibration software. It's all there on the Google page. Once connected, it took about 5 seconds for Google to update/calibrate my sensor. I booted the phone, logged in with a PIN and then tried several apps secured with fingerprint. They all opened like normal. I was able to fingerprint back into the phone. It works fine.
Trazodone - Reply Share
Past 24 Hours: 95
Past 7 Days: 688
Past 30 Days: 2,980
All Time: 246,330
