Google Pixel 8 Pro Earpiece Speaker Replacement
  1. Google Pixel 8 Pro Earpiece Speaker Replacement, Prepare your Pixel for disassembly: step 1, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Prepare your Pixel for disassembly: step 1, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Prepare your Pixel for disassembly: step 1, image 3 of 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Ask FixBot
  2. Google Pixel 8 Pro Earpiece Speaker Replacement, Mark your opening picks: step 2, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Mark your opening picks: step 2, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Mark your opening picks: step 2, image 3 of 3
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  3. Google Pixel 8 Pro Earpiece Speaker Replacement, Tape over a cracked screen: step 3, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Tape over a cracked screen: step 3, image 2 of 2
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Ask FixBot
  4. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the bottom edge adhesive: step 4, image 1 of 1
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
    Ask FixBot
  5. Google Pixel 8 Pro Earpiece Speaker Replacement, Secure the Anti-Clamp: step 5, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Secure the Anti-Clamp: step 5, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Secure the Anti-Clamp: step 5, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
    Ask FixBot
  6. Google Pixel 8 Pro Earpiece Speaker Replacement, Twist the handle: step 6, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Twist the handle: step 6, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Twist the handle: step 6, image 3 of 3
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    Ask FixBot
  7. Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: step 7, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: step 7, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: step 7, image 3 of 3
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
    Ask FixBot
  8. Google Pixel 8 Pro Earpiece Speaker Replacement, Apply a suction cup: step 8, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Apply a suction cup: step 8, image 2 of 2
    • Apply a suction handle to the center of the screen's bottom edge.
    Ask FixBot
  9. Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: step 9, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: step 9, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: step 9, image 3 of 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
    Ask FixBot
  10. Google Pixel 8 Pro Earpiece Speaker Replacement, Prevent damage to your phone: step 10, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Prevent damage to your phone: step 10, image 2 of 2
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
    Ask FixBot
  11. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the bottom edge adhesive: step 11, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the bottom edge adhesive: step 11, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the bottom edge adhesive: step 11, image 3 of 3
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
    Ask FixBot
  12. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the right edge adhesive: step 12, image 1 of 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    Ask FixBot
  13. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the right edge adhesive: step 13, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the right edge adhesive: step 13, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the right edge adhesive: step 13, image 3 of 3
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
    Ask FixBot
  14. Google Pixel 8 Pro Earpiece Speaker Replacement, Leave a pick in the bottom left corner: step 14, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Leave a pick in the bottom left corner: step 14, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Leave a pick in the bottom left corner: step 14, image 3 of 3
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
    Ask FixBot
  15. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the left edge adhesive: step 15, image 1 of 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    Ask FixBot
  16. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the left edge adhesive: step 16, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the left edge adhesive: step 16, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the left edge adhesive: step 16, image 3 of 3
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
    Ask FixBot
  17. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the top edge adhesive: step 17, image 1 of 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    Ask FixBot
  18. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the top edge adhesive: step 18, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the top edge adhesive: step 18, image 2 of 2
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
    Ask FixBot
  19. Google Pixel 8 Pro Earpiece Speaker Replacement, Prop up the screen: step 19, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Prop up the screen: step 19, image 2 of 2
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable without straining it.
    Ask FixBot
  20. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the screen cable cover: step 20, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the screen cable cover: step 20, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the screen cable cover: step 20, image 3 of 3
    • Use an opening tool to pry up the upper edge of the screen cable cover.
    • Remove the cover.
    Ask FixBot
  21. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the screen: step 21, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the screen: step 21, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the screen: step 21, image 3 of 3
    • Insert the point of a spudger under the top right corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Ask FixBot
  22. Google Pixel 8 Pro Earpiece Speaker Replacement, Screen information: step 22, image 1 of 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Ask FixBot
  23. Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: step 23, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: step 23, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: step 23, image 3 of 3
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
    • Reconnect the screen cable and reinstall its cover.
    • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
    Ask FixBot
  24. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the 5G mmWave antenna: step 24, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the 5G mmWave antenna: step 24, image 2 of 2
    • The next few steps show how to disconnect and detach the 5G mmWave antenna cable. If your phone doesn't have a 5G mmWave antenna, skip the next four steps.
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Insert the tip of a spudger under the top edge of the 5G mmWave antenna's press connector.
    Ask FixBot
  25. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the 5G mmWave antenna adhesive: step 25, image 1 of 1
    Ask FixBot
  26. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the 5G mmWave antenna adhesive: step 26, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the 5G mmWave antenna adhesive: step 26, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the 5G mmWave antenna adhesive: step 26, image 3 of 3
    • Insert the flat end of a spudger between the bottom of the 5G mmWave antenna cable and the midframe, just above the press connector.
    • Twist the spudger to separate the bottom of the cable from the midframe.
    Ask FixBot
  27. Google Pixel 8 Pro Earpiece Speaker Replacement, Peel up the 5G mmWave antenna: step 27, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Peel up the 5G mmWave antenna: step 27, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Peel up the 5G mmWave antenna: step 27, image 3 of 3
    Tesa 61395 Tape
    $8.95
    Buy
    • Grip the bottom of the 5G mmWave antenna cable and gently peel it from the midframe.
    • During reassembly, press the cable back into place on the midframe to secure it with the old adhesive. If it doesn't stick, use thin, double-sided tape to secure it.
    Ask FixBot
  28. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the graphite tape: step 28, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the graphite tape: step 28, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the graphite tape: step 28, image 3 of 3
    • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
    • Insert the point of a spudger under different parts of the graphite sheet and lift until you can grip the sheet with your fingers.
    • The sections of graphite sheet between the rear cameras and the battery will most likely tear. If they do, grip the broken part of the sheet and remove that section.
    • Peel up and remove the entire graphite sheet.
    • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
    Ask FixBot
  29. Google Pixel 8 Pro Earpiece Speaker Replacement, Move the USB‑C cover tape: step 29, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Move the USB‑C cover tape: step 29, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Move the USB‑C cover tape: step 29, image 3 of 3
    • Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
    • Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
    Ask FixBot
  30. Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: step 30, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: step 30, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: step 30, image 3 of 3
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the larger rectangular liner from the shim.
    • Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the remaining liner.
    Ask FixBot
  31. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the USB‑C port cover: step 31, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the USB‑C port cover: step 31, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the USB‑C port cover: step 31, image 3 of 3
    FixMat
    $36.95
    Buy
    • While the Pixel 8 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
    • Remove the cover.
    Ask FixBot
  32. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the midframe: step 32, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the midframe: step 32, image 2 of 2
    • Use a T3 Torx screwdriver to remove the seven 5 mm‑long 3IP Torx Plus screws securing the midframe.
    Ask FixBot
  33. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the midframe: step 33, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the midframe: step 33, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the midframe: step 33, image 3 of 3
    • Remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
    Ask FixBot
  34. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the battery: step 34, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the battery: step 34, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery cable press connector.
    Ask FixBot
  35. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the front camera: step 35, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the front camera: step 35, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the front camera press connector.
    Ask FixBot
  36. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the front camera: step 36, image 1 of 1
    • Remove the front camera.
    Ask FixBot
  37. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the rear camera assembly: step 37, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the rear camera assembly: step 37, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the rear camera assembly: step 37, image 3 of 3
    • Use the point of a spudger to pry up and disconnect all three rear camera press connectors from the top edge of the logic board.
    Ask FixBot
  38. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly: step 38, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly: step 38, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly: step 38, image 3 of 3
    • You may need to hold the 5G mmWave antenna cable out of the way while removing the rear camera assembly screws.
    • Use a T3 Torx screwdriver to remove the two screws securing the rear camera assembly:
    • One 3.5 mm‑long 3IP Torx Plus screw securing the top left corner
    • One 5 mm‑long 3IP Torx Plus screw securing the top right corner
    Ask FixBot
  39. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: step 39, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: step 39, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: step 39, image 3 of 3
    • Insert a spudger between the right edge of the rear camera assembly and frame.
    • Pry the rear camera assembly up and remove it.
    Ask FixBot
  40. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: step 40, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: step 40, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: step 40, image 3 of 3
    $3.99
    Buy
    • Insert one arm of a pair of angled tweezers under the metal neck of the black antenna cable coaxial connector, located on the top left corner of the logic board.
    • Gently lift straight up to disconnect the cable.
    • To reconnect the cable, hold the connector in place over its socket and press down with the flat end of a spudger—the connector should snap into place. If you're having trouble, don't try to force the connector over the socket. Reposition it and try again.
    Ask FixBot
  41. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the 5G mmWave antenna bracket: step 41, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the 5G mmWave antenna bracket: step 41, image 2 of 2
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the 5G mmWave antenna bracket.
    Ask FixBot
  42. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna bracket: step 42, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna bracket: step 42, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna bracket: step 42, image 3 of 3
    • Insert the tip of a spudger in one of the 5G mmWave antenna bracket's screw holes.
    • Pry up with the spudger to dislodge the bracket.
    • Remove the bracket.
    • During reassembly, insert the bracket at a downward angle so the spring contacts and foam pads press up against the 5G mmWave antenna. Press the bracket down to secure it.
    Ask FixBot
  43. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna: step 43, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna: step 43, image 2 of 2
    • Grab the 5G mmWave antenna cable and gently lift the antenna out of its recess.
    • If the cable disconnects from the antenna, don't worry! Use your fingers to remove the antenna. Make sure to reconnect the antenna cable during reassembly.
    Ask FixBot
  44. Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: step 44, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: step 44, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: step 44, image 3 of 3
    • Gently pull the black antenna cable out of its clips on the left edge of the phone and the daughterboard.
    • During reassembly, use the point of a spudger to gently push the cable back into its clips.
    Ask FixBot
  45. Google Pixel 8 Pro Earpiece Speaker Replacement: step 45, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement: step 45, image 2 of 2
    • Gently move the black antenna cable out of its cutout on the bottom right corner of the daughterboard.
    • During reassembly, make sure the cable goes back into the cutout. If it doesn't, it may get damaged when you reinsert the rear camera assembly.
    Ask FixBot
  46. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the earpiece speaker: step 46, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the earpiece speaker: step 46, image 2 of 2
    • Use a T3 Torx screwdriver to remove the 3.5 mm‑long 3IP Torx Plus screw securing the earpiece speaker.
    Ask FixBot
  47. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: step 47, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: step 47, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: step 47, image 3 of 3
    • Insert the flat end of a spudger under the center of the earpiece speaker's bottom edge.
    • Pry the speaker up and remove it.
    • This may take some force. You'll hear a "pop" when the speaker is dislodged.
    • During reassembly, insert the edge of the speaker with an orange gasket at a downward angle into its recess. Then press down firmly on the speaker until it clicks into place.
    Ask FixBot
  48. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: step 48, image 1 of 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: step 48, image 2 of 2
    $3.99
    Buy
    • Insert one arm of a pair of angled tweezers under the metal neck of the black antenna cable coaxial connector, located on the bottom of the earpiece speaker.
    Ask FixBot
  49. Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: step 49, image 1 of 1
    • Unclip the antenna cable from its metal clip that sticks out from the speaker.
    Ask FixBot
  50. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable tape: step 50, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable tape: step 50, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable tape: step 50, image 3 of 3
    • Lift the antenna cable out of its groove in the earpiece speaker to separate the yellow tape securing it.
    • Use tweezers or your fingers to remove the yellow tape.
    Ask FixBot
  51. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable: step 51, image 1 of 1
    • Pull the antenna cable out of its groove and remove it.
    Ask FixBot
  52. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: step 52, image 1 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: step 52, image 2 of 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: step 52, image 3 of 3
    Tesa 61395 Tape
    $8.95
    Buy
    • Light adhesive secures the L-shaped antenna board to the bottom of the earpiece speaker.
    • Use a spudger to pry the antenna board off the earpiece speaker.
    • Remove the board.
    • During reassembly:
    • Before securing the antenna board to the speaker, make sure the board is oriented so the antenna socket is along the same edge as the cable groove.
    • If your replacement speaker has adhesive pre-installed, remove the plastic liner and press the board into place to secure it with the adhesive.
    • If your replacement speaker doesn't have pre-installed adhesive, use thin double-sided tape such as Tesa Tape to secure the board to the speaker.
    Ask FixBot
  53. Google Pixel 8 Pro Earpiece Speaker Replacement, You're left with the earpiece speaker: step 53, image 1 of 1
    • You're left with the earpiece speaker.
    Ask FixBot
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
190,922 Reputation
1,204 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 110
All Time: 2,534
