combo drive won't eject disk
replaced drive and have the same problem
Comments:
Can you give us a history so that we've got something to work with?
by
Add a comment
Chosen Solution
I would suspect a bad optical drive ribbon cable. The cable on this iBook G4 model is fragile. Remove the optical drive and check the ribbon cable silver contacts (the side that connects inside the logic board socket). Check if the contacts are all well aligned and not damaged. If so, replace the ribbon cable.
Score 1
Comments:
+ Ralph
by
Add a comment
Most Helpful Answer
Have you tried shutting off the machine, then booting while holding the trackpad button down? That should tell the machine to force the disc out.
Score 1
Add a comment
I've tried rebooting with the trackpack held and have reset the PMU.
Comments:
Is this the exact same problem you had before you replaced the drive? Where did the new drive come from?
by
Add a comment
same problem as I had before replacing with iFixit drive.
Comments:
Do you mind telling us what that problem was? It seems it might not have been the drive.
by
Is the disk catching at the case? Maybe its a simple misalignment.
by
Add a comment
The disc won't eject from the drive
Comments:
has nothing to do with the hard drive. I don't think I can help you.
by
Add a comment
See these similar answers.
Good Luck,
N
Add a comment
Add your answer
wmcgarry2000 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,921
