2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
How to connect keyboard cable in MBP?
MacBook Pro 15" Santa Rosa
Well, I had a little problem with my keyboard a few weeks ago (could not type 'A') so I opened my laptop up according to MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Keyboard Replacement and cleaned the keyboard up (hoping it would solve that problem)... But then I could not figure how to "slide the keyboard ribbon back into the connector" so I'm left with a laptop without a working keyboard... I've tried stuffing it back in but it would only go in about 1mm, not enough to make the connection... any way to connect it back in?
Score -1
Add a comment
Chosen Solution
It's a cam - it lifts up (very gently from the insertion end) you insert the ribbon cable then push the cam back down.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
3 Comments:
how do i lift it up?
by
Get a magnifying glass, examine the connector. Lift up the black plastic flap holding the ribbon in place (vertical ) slide in the ribbon, press down the flap.
by
oh.. so it is opened from the back? haha ok i'll try again...
by
Add a comment
Most Helpful Answer
See step #11 of the guide you used.
Score 3
1 Comment:
the problem is that the guide does not show the outcome of flipping the flap up... anyone can post a photo of it? haha...
by
Add a comment
Use tweezers, they help in get a little more of cable and then push it into the slot deeper)
Add a comment
Add your answer
xkiller213 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,367
