The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Questions View all
MacBook Air A1466 Not switching on. No magsafe light while trying to c
What part is this?
My Macbook Air 1466 won't switch ON. I tried SMC, PRAM reset nothing works , After opening the MacBook I noticed this part fused. What part is this? Could it be responsible for No charging light and macbook not switching ON?
5 Comments
I'd love to tell you Gareth if I could see it ;-{
Go back into 'Edit' of your question using the 'Options' pull down. Then go back into the 'Media Manager' and double click on the image to place it into your answer where the insert text I-beam is.
by
Thanks for the Quick reply Dan, please find attached the image
by
Gareth - I don't see any damaged components? I do see some staining on the logic board. Can you make a note in the pic on what component you are concerned with.
by
Hi , please check edit image, and what component is it? It directly placed next to the fan (2).
I cannot seem to diagnose what's wrong with my Mac. It used to abruptly shut off and then finally one day it won't come ON. If I connect the Magsafe no green light. But if I connect another different magsafe green light appears .
by
[image|2176972]
When I opened the laptop the only observable repair could have been for the IC. Attached zoom in image ( zoom in more and check ) Does the attached IC have anything to do between the charger & SMC ( symptoms: not booting up, blank screen, no charger light while battery disconnected)
by
Add a comment
1 Answer
Most Helpful Answer
OK, the two large blocks are Inductor coils. The solder joints are what I encounter as the yellow crust is just flux that is left on during the manufacturing process. They look just fine!
I think we need to start the proper diagnostic process.
So starting with the MagSafe connector and port are the surfaces clean and the cable not damaged? Apple Portables: Troubleshooting MagSafe adapters
  • Does the MagSafe charger LED go on when plugged in? If so what is the color and does it change? Amber or Green, or not at all!
  • Is the LED light dim or properly lit?
  • Is it the correct charger and a REAL Apple unit? (see below for more on this)
  • Have you replaced the battery? It might be time.
Lets give this a try - Take the battery out, with nothing plugged in press the power button for a good 15 secs, now plug-in the MagSafe charger did the LED lite? Did the system start up on its own?
Let us know what you discover!
The issues with knockoff chargers!
Please don't buy a cheap knock off unit as they will damage your system! Get the REAL Apple unit directly from Apple Apple 45W MagSafe Power Adapter for MacBook Air
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
Score 1
4 Comments:
Hi Dan,
Yes I've tried troubleshooting charger issues:
1. Tried my charger on another device works fine
2. Their charger on mine turns green but doesnt boot up!
( Hope this helps: my charger on my own device shows no color at all ! But after using a different charger and then connecting my charger turns green!)
My charger is official Apple product. Both ports are clean charger & Macbook.
Have disconnected the battery , pressed the power button and then connected charger still no start up chime, no boot up nothing!
Also some additional info : when my laptop was working few weeks back it used to turn off at random time intervals 15mins, 25 mins, 10 mins etc. The night before it went completely dead it was ON the longest for about 4 hours.
Thanks again Dan
Appreciate the assistance
by
@Gareth Almeida - Where you using the correct wattage charger?
by
Yes 45W for Macbook Air 1466. I feel my issue could be related to SMC based on the symptoms - not booting up, blank screen, power adaptor not turning green. Could you advise some troubleshooting for diagnosing SMC. Thanks
by
Yes you likely have a messed up SMC!
But either you or your friend has a knockoff charger as they should react the same! So its likely the root cause that damaged your system. I would get a newline and hope yours is the bad one not your friends.
The only other thing I can think of is the MacBook Air 13" (Mid 2013-2017) I/O Board MagSafe block is damaged enough that yours fails to make good contact with the charger.
Time to visit someone local who has the the deeper skills, tools and access to the needed components. Otherwise you'll need a new logic board MacBook Air 13" Early 2015 Logic Board Replacement
by
Add a comment
Add your answer
Gareth Almeida will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 1,399
