The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Replace a broken Display Unit / Interchangeable with other models?
Hi there,
it is very difficult to source a new display, mine is broken. Did anyone conduct an exchange of a Display of the MBA 13” Early 2015 successfully? If yes, which Display are compatible to exchange from older models/versions? As far as I have seen, only 2015 & 2017 are interchangeable.
Many thanks,
Marcus
2 Comments
You can buy the same from ifixit to make your Mac work again
by
Hi Amily,
I am living in Germany, would be easier and cheaper for me to source it in Germany. Some EBAY listings offer screens from 2013 and 2014 models, claiming these would be compatible, but I doubt that. So I still would like to get an answer from someone who has exchanged successfully their Display for an 2013 or 2014 MBA Display to be sure I can buy one of those.
Thanks,
Marcus
by
Add a comment
1 Answer
Chosen Solution
Not sure I follow you here the display assembly is the same across the Mac Air models from 2012 to 2017. Apple didn’t alter its design until 2018 with the new unit they released.
Here’s the needed part MacBook Air 13" (Mid 2013-2017) Display Assembly and here is the IFIXIT guide MacBook Air 13" Early 2015 Display Assembly Replacement
Here’s a more local source TheBookYard UK - MacBook Air 13" Complete Display (2013-2017)
Replace a display compatible with the model A1466 Mid 2013 to 2017 MacBook Air 13" laptop. Includes the 1440 x 900 LCD 13.3" screen, aluminum case and camera. Part #661-7475, 661-02397, 661-02505. Image
Product
$314.99
Score 2
2 Comments:
Many thanks Dan,
I am aware that the design has not changed, but sometimes the cables are changed or had another (different) adapter. But if all the cables are 1:1 the same as in the older models, I am glad to hear this as I can source older Airs from 2013 for much less than 2015 models to get a working Display Unit.
Thank you again for your answer!
Regards,
Marcus
by
Go to TheBookYard site and review the other options by its part number (661-7475) if you need a cheaper part.
The issue is the condition of the part not its physical age. I gave you the Grade-A part.
Here's the cheapest one you'll be able to find Grade C But I'll warn you it's not likely to be in the best of shape (scuffs and small dings)
by
Add a comment
Add your answer
MacMarcus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 142
