The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Questions View all
Keyboard backlight working dimly even when on full brightness
My MacBook Air’s keyboard backlight has been working really dim even when I’ve put it on maximum brightness. I’ve tried to lower surrounding brightness and even checked the settings but it’s still not bright enough to type in dark. I’ve tried resetting Mac but it didn’t do anything. I’ve never dropped my MacBook or hit it with anything that might damage the keyboard. Anyone with any suggestions apart from showing it to the Apple center?
Add a comment
1 Answer
Most Helpful Answer
Did you have a liquid spill at some point? It sounds like some of the blacklight LED’s are not lit.
The only way to fix this is to pull the logic board out and then carefully lift the black plastic shield over the keyboard, then the backlight panel. You might be able to clean it and hopefully touch up the solder joints to bring it back to life. If not you’ll need to replace the assembly.
Reference: MacBook Air 13" Early 2015 Logic Board Replacement
You might want to think this through… It might not be worth the effort. Here’s the IFIXIT guide to replace the full uppercase; MacBook Air 13" Early 2015 Upper Case Replacement
MacBook Air 13" Early 2015 Logic Board Image
Guide
Difficulty:
Moderate
1 - 2 hours
MacBook Air 13" Early 2015 Upper Case Image
Guide
Difficulty:
Difficult
1 - 2 hours
Score 3
Add a comment
Add your answer
Nightshade will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 67
