Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Questions View all
Question Closed
Replace battery, but iPod very slow response
I just replaced the battery, and plugged it in to charge. But the iPod is very slow to respond
ADMIN EDIT: Here is the entire context for the question. For those of you who are answering, please look at the context of the question to best answer: first, second, third, forth, fifth, sixth, seventh, eighth, ninth.
Add a comment
Chosen Solution
Have you ever defragmented and optimized your hard drive? Your songs may be scattered all over your drive and it can take a long time to seek them. Tech Tool Pro http://www.micromat.com/ is excellent for this.
Score 1
Add a comment
Most Helpful Answer
I recommend resetting the iPod by toggling the hold switch on and off and then holding the menu and center buttons down simultaneously. If you are still experiencing issues, you may need to perform a restore through iTunes.
Score 1
Add a comment
I just put a 5th generation Ipod Video together from scratch which I have done several times. When I got it together it seemed to work fine when I turned it on and played a song, but I noticed it was slow to respond when scrolling up and down and kept freezing. I tried this (toggling the hold button on and off and holding menu and the center button to reset) and it worked like a charm no more slow response or freezing. Thank you very much!
Add a comment
well, you have two choice: one :fix it by yourself,two:replace it .
if you choose the first , you can see the repair videos on youtube,
if you choose the second, you may buy the screen from http://www.cshidworld.com , the price is cheaper,and
the service is better.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,614
