The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Questions View all
MacBook Air 2015 Screwdrivers
Welcome,
I recently wanted to clean up my Air. I bought a Power 8800c screwdriver - star 1.2x50mm star. Unfortunately, I unscrewed a little and this screwdriver didn't fit.
I don't want to buy the same thing twice, so my question is - what more does a screwdriver need? Are P5 Pentalobe or T5 Torx or Phillips #00 the ones I have? Or maybe I still need the TR8 Torx to dismantle everything?
Thank you in advance for your reply.
Greetings
Add a comment
1 Answer
Chosen Solution
Hi @giorge ,
You will mostly need the P5 Pentalobe and the T5 Torx.
The display hinges will need the T8 Torx.
The trackpad will need a Phillips #00.
Score 2
2 Comments:
Hey, great thanks.
In this case I already have P5 Pentalobe (1.2 mm) and don't need P5 with other dimensions (e.g. 0.8 mm)?
by
That is correct. By the way, P5 should only come in 1.2 mm. 0.8 mm pentalobe would be a P2, and 1.5 mm would be a P6.
by
Add a comment
Add your answer
Gorgio Antonio will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 320
