Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
Does this mean my SMC is functioning?
Hi guys !,
MPB been having issue whereas it does not recognize the battery after an accidental power surge .
magsafe is always green and turns on automatically .
I have been trying to find the burnt item so far and my biggest concern is the SMC
attached is the pic of my Istat sensor menu .
if I'm getting all the reading does it mean that the SMC is safe and functioning ?
the only problem Is that my keyboard shortcut for screen brightness is not working and sometimes it works ( it always work if I shut down and do the CTRL+CMD+P+R reset .
let me know . thanks in advance !
Add a comment
1 Answer
Chosen Solution
The SMC is a critical component of a Mac, if it wasn't working your machine would not even turn on :)
Score 1
3 Comments:
hi arabman, thank you for the reply .
I'm taking about its functions . I assume R5070 hold the responsibility to pass the signal .
so if this is not working properly maybe I can have a go at R5070 , then battery might show up ?
P.S . I I feel like fans are not picking the pace when laptop gets heated .
by
R5070 is a pullup resistor, it doesn't have anything to do with charging circuit.
by
On the fan issue try TG Pro (the small version is free). https://www.tunabellysoftware.com/tgpro/
by
Add a comment
Add your answer
Thilina Gdna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 49
