Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Macbook dead?
Hello,
My macbook fall about one feet directly on the bottom (realy flat fall)
Since, it refuse to boot, when I try, the light on right bottom flashing and nothing...
May you help me? (I've tried to remove ram and replace but nothing, I've looked inside if something was broken but nothing...
When I switch off, I ca heard the hard drive is stopping, the screen is always black but not when i switch on, it light a micro second and still black
Any ideas? logic board??
Add a comment
Chosen Solution
Can you find or borrow an external DVD drive to boot from? If you succeed you can run diagnostics from the external drive. Ralph
Score 1
Add a comment
Most Helpful Answer
Hello!
Good job in replacing the RAM to troubleshoot! That would have been my first suggestion.
It is possible that the sleep sensor was damaged in the fall. It is attached to the battery connector. Try replacing the battery connector/sleep sensor first (make sure to get the correct version for your machine, explained here).
If this does not fix the problem, it may be the logic board.
Good luck!
Score 1
Add a comment
Try using only one RAM slot at at time - you might have a damaged slot or RAM.
Good Luck,
N.
Score 1
2 Comments:
You tried booting with one RAM chip/slot at a time right?
On Install disk there is Disk Utilities which can do a rough check of HD.
Command-D Boot with that DVD in optical drive - should launch Apple Diagnostics.
Good Luck,
N.
by
A screen "flash" is an indicator for BAD RAM. Have you tried other RAM?
by
Add a comment
Tryed to move sleep connector but it seems ok and I think its this is the other side who fall first (where the power connector is, sreen, ...)
The light don't flashing again, but I heard the HDD switch on but nothing on screen...
Add a comment
Any ideas?
How to test if video card dead, screen, or logic board? HDD? without buy each parts?
regards
Add a comment
I have no external DVD player but is it possible to boot directlty from internal DVD? I manage to put installation disk 1 but now i can't exit it or launch anything
Or is it possibe to launch diag from a usb key?
Add a comment
Add your answer
Gregory will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,226
