Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Questions View all
How do I Format new Hard Drive?
iMac "Core 2 Duo" 3.06 24-inch (early 2008)
This is my first try with an iMac, helping a friend replace the hard drive... I usually do PC stuff..
I followed the instructions and replaced the Hard Drive in the iMac with a Western Digital 1 TB Desktop SATA drive. It went in flawlessly. Now I need to FORMAT the new HD. Can someone give me step by step instructions on how to do this? I have tried and tried to find the screen pull down to get to the disk utilities...without success. I put in the Mac OS X install Disc 1 and held down the C key... which brings me to a screen with the apple logo and a rotating circle below, nothing else... How do I get to the disk utilities?
Thanks for your help..
Doc in California
Add a comment
1 Answer
Chosen Solution
You have to boot up from the original system installation disk for that specific machine if using a gray disk. You can also use a retail 10.6.3 retail disk. You can also set it up in Target Mode if you have another Mac. Tell us what you have.
Here's the hard drive installation guide: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Score 4
14 Comments:
I tried to boot up from the original system disk. I am using (2008) OS 10.5.4
I also have a OS 10.6.4 disk and Snow Leopard on the way to us from Apple..
The instructions on the disk say "hold down the C as the computer starts" which I tried, got only a spinning O and apple trademark above.
How do I get the HD Formatted? Where is the disk utilities folder? I think I can format it if I can find this folder...
Thanks
by
Either your optical drive is bad, the disk is damaged or it's the wrong disk for your machine. I'd wait on the Snow Leopard disk.
by
I also replaced the button battery 2032 while it was open, would this change anything?
by
I have yet to see a failed battery on this model. You would usually know if the printer is dropping off line.
by
OK, I understand, but would it make any difference if I changed it to a new 2032 battery? I cannot see anyplace where it says anything about the battery... The printer was fine... course its not my computer.
by
Show 9 more comments
Add a comment
Add your answer
Bill Hawkins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,978
