13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
adding 2GB to existing 2GB
I already have 2GB installed. If i order a 2GB memory ...will there be the space to just add it without removing the original 2GB?
Shubu
Score -1
2 Comments
Did you ever solve this issue??
I'm having the same problem with an old Macbook getting slow.
Paul
by
datukmusic- For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the O.Q., a particular Answer or, for more prompt answers to your unique problem create your own original question. As burried here on a 5yr old thread only those who had marked to track this Question may see it and reply.
by
Add a comment
Chosen Solution
One chip or two
Is there 1GB in each slot? Then you'll have 3GB which is ok - but matched pairs of RAM are recommended.
maximum RAM So you may want to buy 4GB in two 2GB chips
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Score 1
2 Comments:
I actually do not know what is in the slot...because I have not opened up the laptop yet. All I know is that there is 2GB installed. Is there a way to figure out if the laptop has space for another 2GB without opening the laptop?
by
Under Utilities -System Profiler ->Memory it will tell you what's in each slot without having to open the box.
by
Add a comment
Most Helpful Answer
Click on About this Mac in the upper left corner. Then select more info and go down to where it says memory. It will tell you what memory is in which slot.
Score 3
2 Comments:
+ agreed
by
Add a comment
Well if you have to 2GB it sound like you have a pair of 1GB. If you bought the MB from a Apple store. So you'll have to buy pair of 2GB. Apple say this MB max is 4GB but aftermarket say 6GB max(1x2GB and 1x4GB), but some say the system won't be sable, try that at your own risk.
Hope that helps and good luck with that.
Add a comment
Add your answer
Shubu Mitra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,185
