Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
iPhone 5 IC Chip Broken Near LCD FPC, IC Chip Code?
Hi Guys,
I have used this site for many years now and It just about has all the answers that I require. Recently, I have come across abit of a dilemma and I thought it would be great to post it on here incase there are others out there having the same issue.
The problem is from a mistake of mine. While i was disconnecting the LCD I pushed the tool down on the board damaging one of the IC chips. I am told it is known as a Display IC Chip. The location is right next to the LCD FPC connector. There are 3 chips located there. 1 of them has broken off. Now the iphone will not display anything but you can hear all the noises of the phone and it functions normally (i.e. touch works etc). I noticed this chip broken off straight away because I was sure that the lcd was fine.
So I was wondering if anyone knows more about this type of chip and how much and where it can be purchased?
Thanks.
3 Comments
For some reason I cannot see the photo that I have tried to upload. I am not sure if you guys can see it. If not please let me know how to upload it. Thank you
by
Wasim Ayoub, to post an image with your question, follow this guide Adding images to an existing answer
by
I'm also looking at an issue like this. I think mine is a backlight chip. Where can I get the schematic image the Tom has?
by
Add a comment
Most Helpful Answer
I have the logic board schematics, which part broke off?
Score 3
3 Comments:
will you help me find the replacement for l44 on the board how do I cross-ref the correct replacement 4 pin chip? Thanks a bunch
by
vitalyuk, L43 and L44 are identical. Both are a 90OHM-50MA in a TCM0605-1 package filter choke.
by
Hi Tom, I have an iPhone 5 and the screen wont display, just chimes every 2 secs, its fully restored on itunes. i was checking the connector for damage and noticed that L41 had broken off. I presume L41,2,3 etc are all the same part?
Would this component be responsible for the LCD not working?
What does the choke do, provide some signal isolation?
by
Add a comment
I know a great source---the piece of tape in your picture. Why not put it back on?
Score 3
Add a comment
I belive the chip in question is L43, and from what i can understand this is LCD Data filter, and can be rectified by running two vertical trace wires on pads.(if someone could please confirm this) I was lucky enough the filter IC was stuck under the tape in my case dont forget to check if its still stuck there. Hope this helps someone.
Update
+ here is picture of problem in my case
Score 1
1 Comment:
You could do that, if you wanted to bridge the component. Why not replace it properly with a TCM0605-1 90OHM-50MA filter choke? That way you know you have a proper repair
by
Add a comment
Tom Chai,
Thanks I have also got the schematics to try and get a exact model number for the IC. The IC is the L45 to be exact.
oldturkey03 where will i get a TCM0605-1 900HM-50MA filter choke?
Thanks guys for the help
1 Comment:
depends where you are located. I usually use mouser.com or digikey.com for SMD components.
by
Add a comment
thanks may deare ferend i hope victory in life for you
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 12,356
