Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Question Closed
Backlight connector needs to be replaced on MacBook 13" (2007)
The back light goes in and out. The connector was not replaced when it was getting repaired now it is messed up.
Anyway would love to get help on how to fix it. I can get the part for like $20-30 instead of paying $100+ for labor.
7 Comments
What are the last three digits of your serial number? This might help us finding the right part for your computer.
by
Last serial # is Z62
by
MacBook "Core 2 Duo" 2.0 13" (White-SR) 2.0 GHz Core 2 Duo (T7300)
by
Post an image of the part that you find "messed up" with your question...
by
Well, I know what it is. While I browsing this website I found the piece. I just didn't remember the name. As I saw the step by step guide I'm not even sure if I am capable of trying to fix it. Also I see there is 2 different models.
Anyway my issue was my screen kept flickering on/off and the cable I needed was something inverter.
Sorry if I wasted your time.
by
Show 2 more comments
Add a comment
Chosen Solution
That''s a very advanced/finicky DIY repair an easier DIY repair (you could easily end up doing this anyway if the light replacement is beyond you) is to replace the entire display. You have to remove the display to get at the light, then disassemble/reassemble the display.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Most Helpful Answer
Sounds like your Inverter and the inverter cable need replacing, follow these guides:
MacBook Core 2 Duo Inverter Image
Guide
MacBook Core 2 Duo Inverter Replacement
Difficulty:
Difficult
2 hours
MacBook Core 2 Duo Inverter Cable Image
Guide
MacBook Core 2 Duo Inverter Cable Replacement
Difficulty:
Difficult
1 - 3 hours
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 203
