Shop the Holiday Gift Guide
Whirlpool Freezer Ice Building Up
Introduction
If there is a buildup of frost, ice, snow, and frozen water in all its forms on the back wall, you're on the right page. If you are more specifically talking about an ice maker that won't stop making ice, follow the fixes on the ice maker problem page.
Causes
Ice buildup happens when warm and humid air contacts cold evaporator coils in the freezer. This moisture freezes and quickly forms a wall of ice. By ensuring food is at room temperature before being placed into freezer containers, you will avoid releasing warm air into the freezer.
The evaporator fan blows cold air around the freezer. While the freezer is more efficient when it is appropriately loaded with food, too much food or incorrectly placed food will block the vents and prevent proper temperature regulation. The refrigerator vents allow for airflow between the fridge and freezer compartments. Blocking these vents may result in many issues.
- Locate your evaporator fan and move frozen items further away.
- Unblock the vents. A rule of thumb for frost prevention is to stock enough food to fill the freezer while keeping an inch of space between the food and the walls.
Door seals are gaskets for your fridge, and as they age and fall apart, cool air escapes through the cracks in door seals.
If the evaporator cover in your freezer is covered in ice crystals, or otherwise frozen over, there's an issue with your defrost system.
Frost-free appliances regulate temperature to prevent ice build-up. Automatic and adaptive defrost systems prevent and remove ice build-up by circulating heat as needed; automatic systems typically run on a timer, while adaptive systems use sensors to determine when to circulate the heat.
The most modern freezers have an auto-defrost system. This defrost system has four main parts: a defrost heater, a bi-metal thermostat, an electronic control board, and a thermistor. Let's begin troubleshooting the defrost heater system.
- Test to see if the defrost heater works. Put your freezer into forced defrost mode. On some models this mode is entered by pushing the door sensor 5 times in 2 seconds. The controller will beep and the defrost mode will start. This mode can be exited by unplugging the fridge.
- If this procedure doesn't work, check the tech sheet located under or behind your fridge for your specific procedures.
- Check to see if the heater heats up.
- If it heats up, jump to the thermistor section.
- If it doesn't heat up, begin troubleshooting the system starting with the defrost heater.
The defrost heater melts frost off the evaporator fins. If the defrost heater fails, the frost stays put, and the entire evaporator eventually becomes ice.
- Locate the defrost heater. If you notice any bumps or cracks, replace it immediately.
- Continuity test the heater. A resistance value outside 50-120Ω will need to be replaced with a new unit.
Find compatible replacement parts for your Whirlpool Refrigerator. All parts and fix kits are backed by the iFixit Quality Guarantee.
The defrost timer initiates 30-minute heating cycles every 8-10 hours of fridge run time. If this unit fails, your fridge will be stuck in either the heating or cooling cycle. It's time to test the defrost timer.
- In units with an adaptive defrost control board, you'll have to enable the defrost cycle manually.
- For some models turn the thermostat off for 15 seconds, then on for 5 seconds. Repeat this two more times, then turn the thermostat off.
- The defrost cycle should be turned on. Test the temperature with a thermometer to see if your fridge is heating up.
- With a manual timer, test between terminals 1 and 4 for continuity.
- Continuity here means that the cooling cycle is operating.
- Rotate the manual dial until hearing a click. Now test between pins 1 and 2 for continuity. This means that the heating cycle is working, and there should be no continuity between pins 1 and 4.
- If continuity tests fail or the fridge doesn't enter defrost mode, replace the timer with a new one.
Another problem that prevents your fridge from getting cold enough is a faulty thermistor. The thermistor is a sensor that monitors temperature. It is connected to the control board. If a thermistor is defective, the refrigerator may not cool (or may cool continuously). This is not likely if the compressor is running but the unit is not cooling.
There may be up to four thermistors on your fridge:
- The fresh food compartment thermistor
- The fresh food defrost thermistor
- The freezer compartment thermistor
- The freezer defrost thermistor
The compartment thermistors sense the air temperature in the compartment they are placed in. The defrost thermistors sense the evaporator temperature during a defrost cycle and prevent the defrost heater from overheating the evaporator. Since many refrigerators have evaporators in both the freezer and fresh food sections, you can end up with four (or even five if the unit has an ambient air thermistor)
Grab a multimeter and continuity test the thermistor. Place the thermistor tip into a cup of ice water made from ice, water (just enough to cover the ice), and salt. You will need to find information on the resistance value expected for your refrigerator's various thermistors at 32°F (0°C).
Another possible cause is the defrost thermistor. This can keep the defrost cycle from running fully, allowing ice to build up, which will cause temperature problems in the refrigerator either because the evaporator in the freezer frosts up or because the fresh food compartment defrost is failing in a dual evaporator system.
If the thermistors test ok go on to the next item.
$59.95
4.8
156 reviews
Finally, if ice is still building up, the main control board might be defective. This is not common.
Additional Resources
Fridge Defrost Troubleshooting
Samsung Service Bulletin Ice Maker
Defrost Heater Add on (Note this is for Samsung Refrigerators)
You're seeing solutions for Whirlpool Refrigerator. Select your model to find parts for your device.
Related Problems
15 problems · View all
- Ice Maker Won't Stop Making Ice
- Fridge Not Cooling But Freezer Works
- Makes Humming Noise
- Compressor Running but Not Cooling
- Compressor Not Running
- Sounds and Possible Causes
- Ice Maker Not Dispensing Ice
- Has Freezer Leaking Water Into Fridge
- Ice Maker Only Crushing Ice
- Ice Maker Making Hollow, Small, or Mushy Ice Cubes
- Ice Maker Making Cloudy Ice Cubes
Describe your problem in your own words
