Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Side Buttons Not Responding
When you press the side buttons, they are unresponsive.
Side Buttons Cracked Or Loose
Since the side buttons are made out of plastic and crack easily, they may require replacement.
Side Buttons Have Popped Off
The side buttons may have popped off the case and are no longer functioning with the motherboard. If this happens, you will need to open up the case and readjust the side buttons. See the replacement guide for more information.
Front Camera Not Working
When you turn on the front camera, the screen is black.
Dust On Outside
Check for obstructions covering the camera (which is located in the top right of the tablet when it is oriented with the logo on the bottom). If you do find that there is an excessive amount of dust obstructing the camera’s lens, use a lint-free cloth to gently wipe away the dust.
Faulty Camera
If no obstructions are found, the camera may be broken or damaged and requires replacement.
No Sound In Headphones
Headphones are plugged in, but sound only comes out of speaker.
Headphones Not Completely Plugged In
Check if your headphones are plugged all the way into the audio jack to ensure proper connection to the tablet.
Faulty Headphones
Try using different headphones. If the sound works with the new headphones, then the old headphones are broken.
Faulty Audio Jack
Try using different headphones, ensuring that they are completely plugged into the audio jack. If they do not work, the tablet's audio jack may be damaged.
No Sound From Speaker
There is sound coming from earphones, but no sound comes out of the tablet’s speaker.
Volume is Turned Off
You may have the volume turned off. To turn it back on, use the physical volume control buttons on the side of the tablet, or go to Settings > Device > Sound and raise the volume there.
Faulty Speaker
The speaker may be broken or damaged and requires replacement.
Tablet Won’t Turn On
The tablet will not turn on.
Battery Not Charged
If your tablet won’t turn on, it may be too low on battery. Plug it in and charge your tablet.
Faulty Power Adapter
If your tablet is working properly but will not charge when plugged into the power adapter, try using a compatible charger that you know works on other devices. If it works, you may want to buy a new power adapter or just use the compatible charger.
Loose Charging Port
If the power adapter does not stay in the charging port, the charging port may be damaged or broken.
Faulty Battery
The battery may be broken, damaged, or at the end of its effective life and requires replacement.
Touchscreen Not Responding To Touch
The touchscreen does not register touches.
Screen is Dirty
Clear the screen of any moisture or dirt, which may interfere with the screen’s ability to sense touches.
You are Wearing Gloves
Touchscreens will not work when wearing certain gloves, so make sure you take them off to see if the problem persists.
Digitizer is Broken
If the touchscreen still does not respond after the solutions above, the digitizer may be the problem and will require replacement.
Distorted Display
The colors on the display are distorted.
LCD Screen is Cracked
A cracked LCD screen could cause the display colors to be distorted, and will require replacement.
Device Overheated
If the device overheats, the LCD cable may loosen and distort the colors on the display. Try to firmly hit the screen while the device is laying face-up on a flat surface. If this does not work, the LCD will require replacement.
Water Damage
The display may be distorted due to water damage. Try turning the device off and submerging it completely in uncooked rice overnight. If colors are still distorted once the device is turned on, then the LCD will require replacement.
Susie Chac
141 Reputation
0 Guides authored
UC Davis, Team 2-1, Oliver Fall 2016 Member of UC Davis, Team 2-1, Oliver Fall 2016
UCD-OLIVER-F16S2G1
5 Members
72 Guides authored
1 Comment
My tablet model is 7q at first it wouldn’t turn on, but when it did only the left of the touch screen was working. Does anyone know how to fix it without replacing it? Thanks.
Anastasia Oporto - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 1,218
