Visual Land Prestige Elite 7Q LCD Screen Replacement
  1. Visual Land Prestige Elite 7Q LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Visual Land Prestige Elite 7Q LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 2, image 1 of 2 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 2, image 2 of 2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 3, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 3, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 3, image 3 of 3
    • Wedge a curved metal spudger to remove the speaker.
  4. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 4, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 4, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 4, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
  5. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 5, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 5, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to lift the black tab.
  6. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 6, image 1 of 2 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 6, image 2 of 2
    • Carefully remove the ribbon cable from the black tab.
  7. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 7, image 1 of 2 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 7, image 2 of 2
    • Use a plastic opening tool to remove the camera.
  8. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 8, image 1 of 2 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 8, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
  9. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 9, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 9, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 9, image 3 of 3
    • Lift the tape holding down the battery.
  10. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 10, image 1 of 2 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 10, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
  11. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 11, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 11, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 11, image 3 of 3
  12. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 12, image 1 of 2 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 12, image 2 of 2
  13. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 13, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 13, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 13, image 3 of 3
  14. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 14, image 1 of 1
    • Lift to remove the battery and motherboard from the tablet.
  15. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 15, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 15, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 15, image 3 of 3
    • Lift the tape on the sides.
  16. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 16, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 16, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 16, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
  17. Visual Land Prestige Elite 7Q LCD Screen Replacement: step 17, image 1 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 17, image 2 of 3 Visual Land Prestige Elite 7Q LCD Screen Replacement: step 17, image 3 of 3
    • Be careful on this step - the screen is fragile and can break easily.
    • Wedge a metal spudger underneath the LCD to remove it.
    • Replace the LCD.
2 other people completed this guide.
Sabrina Scholten
621 Reputation
6 Guides authored
UC Davis, Team 2-1, Oliver Fall 2016 Member of UC Davis, Team 2-1, Oliver Fall 2016
UCD-OLIVER-F16S2G1
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 452
