Introduction
Is your Ring Video Doorbell not ringing? Can you not hear your Ring’s notifications? Ring Video Doorbells are susceptible to a range of problems that could cause the device to not ring properly. Check the following possible causes to identify and solve the problems.
If your Ring Video Doorbell refuses to connect to Wi-Fi or you are not receiving notifications, there could be a problem with your Wi-Fi router channel or the router placement. See this Ring Video Doorbell Has Poor or No Wi-Fi Signal problem page instead.
If your Ring Video Doorbell has poor video quality at night or does not record at night time, see the Ring Video Doorbell has Night Vision Malfunction problem page instead.
Causes
If the microphone on the Ring Video Doorbell is not enabled, you will not be able to receive or hear any sound. Make sure that the microphone has been enabled on the Ring device by going to the Ring Doorbell app and toggling the microphone button. If the issues persist, you may need to replace the Ring’s microphone. Use the Ring Video Doorbell Quick Install Guide to replace the device’s microphone.
First, check to make sure that the audio is enabled from the Ring application and the Ring Doorbell. If the Ring’s speaker is not responsive and no sound can be heard, the speakers might need to be replaced. Use this Ring Video Doorbell Pro Speaker Replacement guide to replace the Ring’s speakers.
- 5 - 25 minutesModerate
Describe your problem in your own words
