Introduction
If your Logitech M185 Wireless Mouse doesn't work after you've switched it on, follow this troubleshooting guide for help.
Before you start troubleshooting the Logitech M185 Wireless Mouse issue, make sure that your mouse is switched to "Off" mode. This minimizes the chance of any unintentional damage being done to your device.
Causes
A common but simple mistake is when the batteries are misplaced or not properly inserted. Check the batteries to see if they are in the proper position. The flat side or the negative end of the battery should be facing the spring inside the mouse. Likewise, the bumpy side or the positive end of the battery should be facing toward a flat interior.
If the receiver isn't plugged into the other device all the way, your mouse and the device will not be able to communicate and the mouse won't work. To make sure that it is working, slowly wiggle the receiver. If you find that it easily moves out of place, then it hasn't been placed properly.
Another common issue with batteries is when the owner(s) are unaware of whether or not the battery they're using is dead. To determine whether or not your battery is dead, conduct a fall test. A fall test is simple to conduct and can help diagnose a dead battery. However, you will need a spare battery, preferably one that's brand new. You're going to want to drop both of the batteries on their end. The brand new battery shouldn't bounce, while a potentially dead battery should.
If you've tried everything else, it may be that the main board is defective. The main circuit board is essential to a functioning mouse and if it is damaged or defective it needs to be replaced. Use this motherboard replacement guide.
- 10 - 20 minutesModerate
Describe your problem in your own words
