Logitech G X56 HOTAS Throttle Non-Responsive Toggle Switch
Are the toggle switches on the face of your Logitech G X56 HOTAS Throttle missing inputs or be an entire array isn't sending inputs? Are the LEDs are not paired with the switches and will not display the symptom? Use this troubleshooting guide to help diagnose why.
Causes
This may be a singular switch that seems unresponsive and does not give any input.
  1. The x56 software does have a key tester built into it. Load the software and confirm if the switch is operational. If it is operational, ensure it is bound to a function in other software.
  2. If it is not operational, replace the switch board.
  3. Back Plate Disassembly
  4. Logic and Power Board Replacement
  5. Switch Board Replacement
2
It is also possible for an entire group of switches to be dead. If this is the case, then the likely culprit is the board, and it should be replaced.
  1. Back Plate Disassembly
  2. Logic and Power Board Replacement
  3. Switch Board Replacement
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:2
Past 30 Days:30
All Time:310
