Kenmore Electric Dryer Error Codes
Modern dryers have digital displays which convey error messages when parts fail or something is simply not right. Older dryers may not have digital displays and instead use a series of LEDs to signal that a component isn't working correctly. Diagnose your code below.
Before undertaking any of the more time consuming solutions below, these are a few fundamentals to get you started.
  • Make sure there is power at the wall outlet.
  • Check if a household fuse is blown or if a circuit breaker tripped
  • Check that the dryer vent is properly installed and clear of lint or obstructions.
  • Check all connections before replacing components. Look for broken or loose wires, failed terminals, or wires not pressed into connectors far enough.
  • A potential cause of a control not functioning is corrosion on connections. Observe connections and check for continuity with an ohmmeter.
  • Connectors: Look at the top of the connector. Check for broken or loose wires. Check for wires not pressed into the connector far enough to engage metal barbs.
  • Resistance checks must be made with dryer unplugged or power disconnected.
Causes
Issue: PF flashes to indicate that a power failure occurred while the dryer was running. Press START to continue the cycle, or press STOP to clear the display.
2
Issue: AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not obstructed.
3
Issue: F-01 flashes when there is a primary control failure. Replace the machine control electronics.
4
Issue: F-02 flashes when there is a stuck button or user interface mismatch. This fault code will ONLY appear when in the diagnostic test mode.
5
Issue: F-22 flashes if the exhaust thermistor is open.
6
Issue: F-23 flashes if the exhaust thermistor has shorted
7
Issue: F-24 ******flashes if the inlet thermistor is open. This fault code will ONLY appear when in the diagnostic test mode
8
Issue: F-25 flashes if the inlet thermistor is shorted. This fault code will ONLY appear when in the diagnostic test mode
9
Issue: F-26 flashes if there is a motor drive system failure
10
Issue: F-28 flashes if the moisture sensor strip is open. This fault code will ONLY appear when in the diagnostic test mode
11
Issue: F-29 flashes if the moisture sensor strip has shorted. This fault code will ONLY appear when in the diagnostic test mode
12
Issue: F-30 flashes if a restricted airflow condition exists. This fault code will ONLY appear when in the diagnostic test mode. Check to make sure the lint screen is clean, the door seal is in place and the vent is not obstructed.
13
Issue: F-40 flashes if the communication between the machine control and motor control is lost.
14
Issue: F-41 flashes when there is a blower motor failure.
15
Issue: F-42 flashes if the motor control detects a voltage less than 90 VAC
16
Issue: F-43 flashes if the motor control detects a low voltage condition. The dryer will continue to run at a set blower speed.
17
Issue: F-44 flashes when there is a motor control electronics failure
18
Issue: F-45 flashes when there is a motor control electronics speed sensor failure
19
Issue: F-46 flashes if the motor control detects an over-current or an over-torque condition
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:28
Past 30 Days:122
All Time:6,172
