GameSir X5 Lite Won't Connect
Will your GameSir X5 Lite not work while connected to the mobile device? Use this troubleshooting guide to help diagnose why.
Causes
Sometimes a mobile device’s connection port is dirty and needs cleaning before it can connect properly to the GameSir X5 Lite. Power off the mobile device, then use compressed air to clear away dust/debris. If any persistent dust/debris remains, use a small, non-metallic tool, such as a toothpick, to gently remove it.
2
If a connection isn’t established while a mobile device is in a case, the case might be blocking the connection. “Heavy-duty” cases, such as tough or rugged cases, will need to be removed because their size will likely prevent a proper connection with the GameSir X5 Lite.
In general, it is recommended that any case be removed to ensure a full connection with the charging port.
3
Sometimes an update is needed for the GameSir X5 Lite to work properly. Updates can be found in the official GameSir app, available to download on the Google Play Store and the Apple App Store for Android and iOS devices, respectively.
The GameSir X5 Lite can be used without downloading the GameSir app, but it is highly recommended to install it to ensure the firmware is up to date.
4
If the GameSir X5 Lite’s USB-C cable cannot connect to the mobile device, it may need to be replaced.
Ensure that the GameSir X5 Lite's USB-C cable is not obscured or poorly connected to the mobile device before replacing it.
5
The GameSit X5 Lite might not work if the mobile device it’s connected to hasn’t been updated recently. To update a mobile device, go to Settings> System Update (Android) or Software Update (iOS).
Describe your problem in your own words
View statistics:
Past 24 Hours:19
Past 7 Days:193
Past 30 Days:795
All Time:2,651
