Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The GameSir X5 Lite is a budget mobile controller in the GameSir X-series. Released on April 30th, 2025, at a price point of $34.99 USD. The GameSir X5 Lite is available for mobile gamers worldwide.
The GameSir X5 Lite is compatible with most mobile devices, allowing a device to be connected to the controller's middle, akin to the Nintendo Switch. It measures at 196.7*88.3*46.2mm/7.774*3.48.1.82in and extends up to 213mm. It weighs 135.4g and some of its physical features include hall-effect sticks, textured grips, and membrane buttons. It comes in two colors: Wasabi and Black.
 The GameSir X5 Lite contains core features of a standard mobile controller, including quick connectivity, pass-through charging, turbo function, and hall-effect sticks for anti-drift. The GameSir X5 Lite features a lightweight, durable design for long-term gaming. Reviewers have praised the GameSir X5 Lite for these features and price point, with The Sixth Axis commending it for its quality, comfort, and hall-effect sticks.
There has been no official recall of the GameSir X5 Lite, and complaints about the controller mainly concern connectivity issues and button problems. There are no other models released as a direct upgrade to the GameSir X5 Lite, as it serves as a unique budget option. Yet there is another product in the X-series known as the GameSir X5s, with additional rumble and motion-control features, but at a higher price point than the GameSir X5 Lite.
Identification
The GameSir X5 Lite can be identified by its compact, lightweight design and telescopic controller body that expands to fit most smartphones. It features a split controller layout with controls on both the left and right sides of the phone when extended. The controller connects through a USB-C connector located on the right side of the device, allowing it to plug directly into compatible phones. The front includes standard gaming controls such as dual joysticks, a D-pad, ABXY buttons, shoulder buttons, and triggers. The GameSir logo is typically located on the front of the controller, and the model name “X5 Lite” appears on the packaging and product labeling. Its lightweight build and integrated USB-C connection distinguish it from other GameSIr controllers that use Bluetooth or detachable grips.
Technical Specifications
Device: GameSir X5 Lite
  • Manufacturer: GameSir
  • Release Date: April 30, 2025
  • Launch Price: $34.99 USD
  • Controller Type: Telescopic mobile gaming controller
  • Connectivity: USB-C wired connection
  • Compatible Platforms: Android smartphones and other USB-C mobile devices
  • Supported Phone Length: 105–213 mm (4.13–8.39 in)
  • Dimensions: 196.7 × 88.3 × 46.2 mm (7.74 × 3.48 × 1.82 in)
  • Weight: 135.4 g (4.8 oz)
  • Analog Sticks: Hall-effect joysticks
  • Buttons: Membrane ABXY buttons
  • D-Pad: Membrane D-pad
  • Triggers: Membrane triggers
  • Turbo Function: Supported
  • Pass-Through Charging: Yes
  • Power Source: Powered by the connected device (no internal battery)
Available Colors: Wasabi, Black
Sources
Additional Information
GameSir X5 Lite Mobile Game Controller User Manual (EN, JA, KO, RU, DE, FR, ZH, IT, ES, PT, PL)
Past 24 Hours: 39
Past 7 Days: 196
Past 30 Days: 915
All Time: 3,370
