Shop the Holiday Gift Guide
Touchscreen Not working
Kalen and 1 contributor
Last updated on
If your Dell Venue Pro touchscreen does not respond to taps, swipes, or gestures, follow this page for possible solutions.
Causes
A frozen process or temporary bug can stop the touchscreen from responding.
  • Perform a soft reset by holding the Power button for 10–15 seconds until the device restarts.
  • If unresponsive, plug in the charger and repeat the reset.
  • Once restarted, test the screen again on the lock screen or home menu.
If touch input returns after rebooting, the issue was likely software related.
2
Dust, fingerprints, or moisture can interfere with capacitive touch detection.
  • Power off the device and unplug any cables.
  • Wipe the screen gently with a soft microfiber cloth.
  • Avoid using excess liquid—if needed, lightly dampen the cloth with a 70% isopropyl alcohol solution.
  • Dry the screen completely before powering on.
3
If the screen is clean and powered, an internal cable may have loosened.
  • Power off and open the device carefully.
  • Locate the touchscreen digitizer connector near the display assembly.
  • Reseat the cable by unplugging and reconnecting it securely.
  • Reassemble and test the touchscreen again.
If touch still fails, the digitizer itself may be damaged.
4
Incorrect touchscreen drivers can cause loss of functionality.
  • Connect a mouse or keyboard to the device.
  • Open Device Manager → Human Interface Devices.
  • Locate the HID-compliant touchscreen entry, right-click, and select Update driver.
  • If the touchscreen entry is missing, enable “Show hidden devices” and reinstall the latest Dell driver package from the official website.
  • Restart the device after installation.
5
Some screen protectors or tight-fitting cases can block touch input.
  • Removes any screen protectors, cases, or covers.
  • Test the screen without accessories attached.
  • If responsiveness improves, use a thinner or compatible protector.
6
If all other steps fail, the touchscreen hardware may be defective.
  • Connect the device to an external monitor to confirm that other functions work.
  • If the display image appears fine externally, the issue is isolated to the touchscreen digitizer.
  • Replace the display assembly.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:17
Past 30 Days:65
All Time:241
