DJI Mini 2 Unstable When Hovering
Causes
To recalibrate the compass in the drone go to the drone’s settings in the DJI Fly app. From there, go to Settings, Control, and scroll down to Sensors. In the sensor section, the app will guide you through the rest of the calibration process.
2
When you need to recalibrate the controller, the control should be beeping and will continue until you fix it. To recalibrate the controller you open the DJI Fly app, go to Settings, then Control, and scroll down the RC Calibration. In the RC Calibration section, the app will guide how to finish this process.
3
Adjusting the weight of the original drone can cause it to struggle while hovering. To prevent this use the original parts provided by DJI.
4
For a drone to maintain a hover, the drone needs all the motors to spin at the same speed. If the motors are not running at the same speed, check them to see if they have any debris stuck in them. To clear out debris used a can of compressed air to spray the motor. If the motors themselves are damaged, they will need to be replaced.
5
If the propellers are damaged or loose this will cause the drone to fail to hover. Replace the propellers or tighten them accordingly.
6
If the drone's body is damaged, the drone can fail to hover. Replace the drone body to fix this.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:15
Past 30 Days:47
All Time:1,802
