Causes
If you are out of range of the Bluetooth device, then your phone or tablet will not connect. To fix this problem you will need to relocate closer to your Bluetooth device and try connecting again. After the connection is successful make sure not to move too far from said device to stay connected.
If you cannot connect to the Bluetooth, then more than likely the Bluetooth chip or board is damaged. To fix this problem then you will need to replace the motherboard. The Anker Soundcore Select 2 A3215 comes with an auxiliary cord so you can connect to another device without Bluetooth.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:7
Past 30 Days:20
All Time:113
