Anker Soundcore Select 2 A3125 Not Charging
If your Anker Soundcore Select 2 A3125 speaker isn't charging as expected, this troubleshooting guide may provide some solutions.
Causes
Visually inspect the charging cable for any physical damage. Look for damage to the connector, or a crimped/frayed part of the cable. If there are no signs of damage, plug the cable into a different device. If it still does not charge, the charging cable is broken and must be replaced.
2
If the speaker works while plugged in, the charging port and charging cable do not need replacement, and the speaker dies shortly after removing it from the charger; the battery must be replaced. Follow this guide to replace the battery in your speaker.
3
For the Select 2, an LED indicator shows that the device is charging. If this light isn’t on, the charging port likely needs to be replaced. Follow this guide to replace the charging port.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:2
Past 30 Days:16
All Time:121
