Up to 20% off select tools
Acer Chromebook Won't Connect to WiFi
Jacob Mehnert and 2 contributors
Last updated on
Before diving into advanced troubleshooting, start with these basic tips to ensure proper WiFi connectivity.
  1. Check WiFi Signal: Verify that your Acer Chromebook is within range of a functioning WiFi network. Ensure you are within the router's range and that no physical obstructions are blocking the signal.
  2. Ensure WiFi is Enabled on your device: Press the WiFi key (usually represented by an antenna icon) on your Chromebook's keyboard to ensure WiFi is enabled. You can also check by clicking on the system tray in the bottom-right corner of the screen and ensuring the WiFi icon is turned on.
  3. Check for Airplane Mode: Make sure your Chromebook is not in Airplane Mode, which disables all wireless connections. Disable Airplane Mode by clicking on the system tray and turning off the Airplane Mode icon.
  4. Double-check WiFi Password: If you connect to a password-protected WiFi network, ensure you enter the correct password. Pay attention to uppercase and lowercase letters, special characters, and spaces.
  5. Test with Another Device: Verify if other devices can connect to the same WiFi network. If other devices are also experiencing connectivity issues, the problem may lie with the WiFi network itself.
  6. Restart your Chromebook and the Router: A simple restart can sometimes resolve temporary connectivity issues with both devices.
If the above steps don't resolve the issue, proceed to the more in-depth troubleshooting below.
Causes
ChromeOS sometimes has issues connecting to a network if your device is automatically assigned an IP address. This issue can be resolved by forgetting the WiFi network and then reconnecting to it.
  1. Click on the WiFi Icon: Click on the WiFi icon in the system tray to open the network list.
  2. Find the Affected WiFi Network: Locate the WiFi network to which your Acer Chromebook is having trouble connecting. Click on the network name to expand the connection options.
  3. Click on "Forget": Once the connection options are expanded, click the "Forget" button next to the network name. This will remove the network from your saved list.
  4. Reconnect to the Network: After forgetting the network, click the WiFi icon again and select the network from the list. Enter the correct password and attempt to connect.
  5. Check Connection: Once connected, check if your Acer Chromebook can access the internet through WiFi.
2
If a cached file becomes corrupted, it can cause issues connecting to your network. Clearing the WiFi network data can help resolve issues with saved network settings. Follow these steps:
  1. Open Settings: Click on the system tray and the gear-shaped "Settings" icon to open the Chromebook settings.
  2. Expand "Advanced": Scroll down and click on the "Advanced" section to reveal additional settings.
  3. Click on "Privacy and Security": Under the Advanced section, click "Privacy and Security" to access related settings.
  4. Click on "Clear Browsing Data": In the Privacy and Security section, click "Clear Browsing Data" to open the data clearing options.
  5. Choose WiFi Networks: Check the "Cookies and other site data" option in the Clear Browsing Data settings settings. Uncheck any other options that you don't want to clear.
  6. Click on "Clear Data": Once the desired options are selected, click the "Clear Data" button to clear the WiFi network data.
  7. Reconnect to the Network: After clearing the data, attempt to reconnect to the WiFi network and check if the issue is resolved.
4
Sometimes, the device's internal WiFi card might be experiencing an issue. Before opening the device up, be sure to check the following.
  • Restart the network card: Press the refresh key (usually located where the F3 key would be) and tap the power key. Release the keys once your Chromebook restarts. This will refresh the network card and may resolve any temporary issues.
  • Update network card drivers: Ensure your Chromebook's operating system is current. Go to "Settings" > "About Chrome OS" > "Check for Updates." Install any available updates, including updates for network drivers.
  • Test with an external Wireless Adapter: Using a wireless adapter, you can ensure your device can reach the network and determine if your WiFi card needs replacing. However, if you cannot reach the WiFi with an external adapter, there is likely an issue with your device's Motherboard.
  • Replace the Network Card: If all else fails, you can replace your device's network card and see if it is able to detect your wireless network.
If these steps have failed, there is most likely an issue with your device's motherboard.
Jake Mehnert
With a passion for tech repair and over six years of hands-on experience, I’ve worked extensively on laptops, from MacBooks to Acer Chromebooks, while diving into game console hardware repairs for Xbox, PlayStation, and Nintendo Switch controllers. My career began with maintaining Point of Sale systems in a major theme park, where I developed a keen eye for diagnosing hardware issues. Now, I apply my skills in an educational setting, tackling everything from computer repairs for students and teachers to network troubleshooting. I hold Network Administration, Cybersecurity certifications, and more, backed by a Bachelor's in Computer Science.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:19
Past 30 Days:111
All Time:7,714
