Battery Disconnection
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Battery Disconnection, Safety Precautions: step 1, image 1 of 1
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Battery Disconnection, Heat the bottom edge: step 2, image 1 of 1
    • Lay the phone down on a clean, smooth surface so the back glass is facing up.
    • Heat an iOpener and apply it to the bottom edge of the back glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the displays and/or internal batteries, so proceed with care.
  3. Battery Disconnection, Anti-Clamp instructions: step 3, image 1 of 3 Battery Disconnection, Anti-Clamp instructions: step 3, image 2 of 3 Battery Disconnection, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Unfold your phone completely and slide the Anti-Clamp arms over the left edge of the back glass, below the Google "G" logo.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Make sure the suction cup on the inner screen isn't touching the bezel, as it won't stick properly.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface. If the glass if cracked, use packing tape to help the suction cups adhere.
  4. Battery Disconnection: step 4, image 1 of 3 Battery Disconnection: step 4, image 2 of 3 Battery Disconnection: step 4, image 3 of 3
    • Place an object under your phone, like a box or a stack of books, so it rests level while between the Anti-Clamp's arms.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, detach the suction cups and realign the arms.
  5. Battery Disconnection: step 5, image 1 of 1
    • Insert an opening pick into the gap under the back glass.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. Battery Disconnection, Insert an opening pick: step 6, image 1 of 3 Battery Disconnection, Insert an opening pick: step 6, image 2 of 3 Battery Disconnection, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction cup to the back glass, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back glass and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back glass.
  7. Battery Disconnection, Separate the bottom adhesive: step 7, image 1 of 3 Battery Disconnection, Separate the bottom adhesive: step 7, image 2 of 3 Battery Disconnection, Separate the bottom adhesive: step 7, image 3 of 3
    • Don’t insert the opening pick deeper than 3.5 mm when separating the back glass adhesive, as you risk damaging internal components.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom left corner before continuing.
  8. Battery Disconnection, Heat the left edge: step 8, image 1 of 1
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
  9. Battery Disconnection, Separate the bottom left adhesive: step 9, image 1 of 2 Battery Disconnection, Separate the bottom left adhesive: step 9, image 2 of 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Battery Disconnection, Separate the left adhesive: step 10, image 1 of 3 Battery Disconnection, Separate the left adhesive: step 10, image 2 of 3 Battery Disconnection, Separate the left adhesive: step 10, image 3 of 3
    • Insert a second opening pick at the bottom left corner.
    • Slide the opening pick toward the top left corner to separate the adhesive.
    • Leave the opening pick in the top left corner before continuing.
  11. Battery Disconnection, Heat the top edge: step 11, image 1 of 1
    • Apply a heated iOpener to the top edge of the back glass for two minutes.
  12. Battery Disconnection, Separate the top left adhesive: step 12, image 1 of 2 Battery Disconnection, Separate the top left adhesive: step 12, image 2 of 2
    • Rotate the opening pick around the top left corner to separate the adhesive.
  13. Battery Disconnection, Separate the top adhesive: step 13, image 1 of 2 Battery Disconnection, Separate the top adhesive: step 13, image 2 of 2
    • Insert a third opening pick in the top left corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
  14. Battery Disconnection, Heat the right edge: step 14, image 1 of 1
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
  15. Battery Disconnection, Separate the top right adhesive: step 15, image 1 of 2 Battery Disconnection, Separate the top right adhesive: step 15, image 2 of 2
    • This sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the back glass.
    • Rotate the opening pick around the top right corner to separate the adhesive.
  16. Battery Disconnection, Separate the right adhesive: step 16, image 1 of 3 Battery Disconnection, Separate the right adhesive: step 16, image 2 of 3 Battery Disconnection, Separate the right adhesive: step 16, image 3 of 3
    • Insert a fourth opening pick in the top right corner.
    • Slide the opening pick toward the bottom right corner to separate the adhesive.
  17. Battery Disconnection, Separate the bottom right adhesive: step 17, image 1 of 2 Battery Disconnection, Separate the bottom right adhesive: step 17, image 2 of 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  18. Battery Disconnection, Reposition the back glass: step 18, image 1 of 3 Battery Disconnection, Reposition the back glass: step 18, image 2 of 3 Battery Disconnection, Reposition the back glass: step 18, image 3 of 3
    • Don't fully remove the back glass yet, as it's still connected to the phone by a cable.
    • At this point, the back glass should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Swing the left edge of the back glass up and over the right edge of the phone.
    • Lay the back glass to the right side of the phone before continuing.
  19. Battery Disconnection, Unfasten the middle bracket: step 19, image 1 of 1
    FixMat
    $36.95
    Buy
    • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the two 2.8 mm‑long screws securing the middle bracket.
  20. Battery Disconnection, Remove the middle bracket: step 20, image 1 of 3 Battery Disconnection, Remove the middle bracket: step 20, image 2 of 3 Battery Disconnection, Remove the middle bracket: step 20, image 3 of 3
    Buy
    • Use tweezers, or your fingers, to pull the middle bracket toward the left edge of the phone and release its clip.
    • Remove the middle bracket.
    • During reassembly, reinsert the middle bracket clip under its slot in the frame before aligning the screw holes.
  21. Battery Disconnection, Disconnect the back glass cable: step 21, image 1 of 2 Battery Disconnection, Disconnect the back glass cable: step 21, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the back glass cable from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  22. Battery Disconnection, Remove the back glass: step 22, image 1 of 1
    • Remove the back glass.
  23. Battery Disconnection, Reassembly information: step 23, image 1 of 2 Battery Disconnection, Reassembly information: step 23, image 2 of 2
    Tesa 61395 Tape
    $8.95
    Buy
    • During reassembly:
    • If you're reusing your back glass, use tweezers to remove big chunks of adhesive from the perimeter of the back glass.
    • Repeat for any adhesive on the frame.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace the back glass adhesive with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the back glass to the frame.
  24. Battery Disconnection, Reposition the graphite sheet: step 24, image 1 of 3 Battery Disconnection, Reposition the graphite sheet: step 24, image 2 of 3 Battery Disconnection, Reposition the graphite sheet: step 24, image 3 of 3
    Tesa 61395 Tape
    $8.95
    Buy
    • The graphite sheet is very fragile. Be gentle peeling the graphite sheet in this step, especially if you're reusing it.
    • The graphite sheet is lightly adhered to the logic board.
    • Peel the bottom of the graphite sheet toward the top of the phone until you can access the bottom bracket.
    • Use your hands, or tape with light adhesive, to keep the graphite sheet out of the way.
    • If you completely removed your graphite sheet, follow this guide to replace it.
    • If you don't have custom cut adhesive strips for the antenna, use double-sided tape, like Tesa Tape, to secure the graphite sheet to the logic board.
  25. Battery Disconnection, Remove the screw cover: step 25, image 1 of 3 Battery Disconnection, Remove the screw cover: step 25, image 2 of 3 Battery Disconnection, Remove the screw cover: step 25, image 3 of 3
    Buy
  26. Battery Disconnection, Unfasten the bottom bracket: step 26, image 1 of 1
    • Use a Torx Plus 3IP driver to remove the five 3.1 mm‑long screws securing the bottom bracket.
  27. Battery Disconnection, Remove the bottom bracket: step 27, image 1 of 3 Battery Disconnection, Remove the bottom bracket: step 27, image 2 of 3 Battery Disconnection, Remove the bottom bracket: step 27, image 3 of 3
    • Use tweezers, or your fingers, to pull the bottom bracket toward the bottom edge of the phone and release its clip.
    • Remove the bottom bracket.
    • During reassembly, reinsert the bottom bracket clip under its slot in the logic board before aligning its screw holes.
  28. Battery Disconnection, Disconnect the base battery: step 28, image 1 of 2 Battery Disconnection, Disconnect the base battery: step 28, image 2 of 2
    • There are two batteries you need to disconnect, one for each half of the phone.
    • Use the point of a spudger to pry up and disconnect the base battery cable press connector.
  29. Battery Disconnection, Remove the tape: step 29, image 1 of 2 Battery Disconnection, Remove the tape: step 29, image 2 of 2
    • Peel the grey conductive tape off the bottom interconnect cable.
  30. Battery Disconnection, Disconnect the flip battery: step 30, image 1 of 3 Battery Disconnection, Disconnect the flip battery: step 30, image 2 of 3 Battery Disconnection, Disconnect the flip battery: step 30, image 3 of 3
    • Use a point of a spudger to pry up and disconnect the flip battery and bottom interconnect press connectors.
    • You have to disconnect both cables to keep the battery connector from accidentally touching the logic board.
  31. Battery Disconnection, Reassembly information: step 31, image 1 of 3 Battery Disconnection, Reassembly information: step 31, image 2 of 3 Battery Disconnection, Reassembly information: step 31, image 3 of 3
    • During reassembly, the next two steps demonstrate how to replace the flip battery and bottom interconnect cable conductive tape.
    • Peel off the new conductive tape from its liner and apply the sticky side to the bottom interconnect connector, making sure to bridge the logic board.
  32. Battery Disconnection: step 32, image 1 of 3 Battery Disconnection: step 32, image 2 of 3 Battery Disconnection: step 32, image 3 of 3
    • Use a spudger, or your fingers, to press down the conductive tape and adhere it.
    • Use tweezers, or your fingers, to pull on the tab and expose the tape.
Alex Diaz-Kokaisl
227,337 Reputation
1,106 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,282 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 153
