Whirlpool Washing Machine Troubleshooting: Fix Common Problems
The first step towards a working Whirlpool Washing Machine is identifying the problem. Select one of our preferred guides below to diagnose and solve Whirlpool Washing Machine common issues.
Whirlpool Washing Machine Error Codes
Has your Whirlpool — or KitchenAid, Maytag, Amana, or Jenn-Air — washing machine thrown an error code? Follow this page to identify the code, and fix the issue.
Whirlpool Washer Not Spinning
Your Whirlpool washer has lost it's whirl. It's more of a pool. It doesn't turn fast and the clothes are wet. We have causes and fixes. Let's get started!
Whirlpool Washing Machine Giving F3E1 Code
Is your Whirlpool Washer giving you the F3E1 code? It is having problems filling? Is it overflowing? Here are some solutions! You can fix this!
Related Washing Machine Problems
Washing Machine Not Spinning
Your washing machine is only getting half the job done. It isn't spinning and the clothes are still wet. The cycle isn't complete. Perhaps the spin cycle isn't really doing its job; it spins but slower. Maybe you have to run it twice. We will look at the possible causes and solutions.
Washing Machine Shaking
In the spin cycle, does your washing machine sound like it's going to shake and bang itself apart? Let's get that machine settled down. Here are some possible fixes.
Washing Machine Won't Turn On
Your washing machine won't start. You press the right button, turn the knob or pull the knob out, but nothing or nothing much. Amazingly there are a lot of fixes that are simple and straightforward. Also, you don't even have to dig into the machine to get going. Let's start with the simple solutions.
Washing Machine Not Draining
Your washing machine is full of water but at the wrong time. Let's get you emptied out and going again.
Experiencing issues with your washing machine can be inconvenient, but many common problems can be quickly resolved through basic troubleshooting. This guide aims to assist you in identifying and fixing prevalent washing machine issues from the comfort of your home.
Washing Machine Is Leaking
Your washing machine isn't holding its water. It's leaking all over the floor. Puddles are forming. You need to track down why. We can walk through the causes of a leaking washer.
Washing Machine Has No Water
Your washing machine has no water to wash the clothes, it will not fill. You turn it on but no water comes in. Maybe the water comes in really slowly. Or maybe it's only just the cold or hot water that flows. What can you do? There are a whole bunch of things to check. Let's go see a solution.
Washing Machine Door Is Locked
Your Washing Machine door is locked and your clothes are stranded inside. This page is meant to help you find a way in, and find out what went wrong. Then we will look at some solutions, once we know what went wrong. Don't despair, you can repair! Most of the issues are centered around failures in the door locking mechanism which is a straightforward fix. Some issues are encountered with defective control parts; in a few cases, these can be caused by the latch failing as well.
