Shop the Holiday Gift Guide
Not Clicking
Last updated on
  • Restart your computer/Restart your Logitech Mouse if needed: Restarting your mouse can sometimes fix temporary glitches or clear out any temporary files that might cause issues. Be sure to shut down your computer completely, turn off your mouse, and remove the batteries to ensure the mouse can power cycle.
  • Try another USB port on your computer: If your computer's USB ports have become worn, then this can impact how your mouse functions. If you have another available port, then try plugging your mouse into a different port.
  • Replace or charge your mouse's batteries: If you're using a wireless mouse, check whether the battery is low or nearly depleted. Replace your mouse's batteries, or make sure the battery is fully charged.
  • Replace your mouse's batteries: If you're using a wireless mouse, check whether the battery is low or nearly depleted.
Causes
Solution: Clean the area around your mouse's buttons
Accumulated dust and debris can become jammed around and under your mouse's buttons, preventing it from compressing properly.
  • Cleaning your Mouse: Cleaning your mouse involves using compressed air or a soft brush, and 90% Isopropyl Rubbing Alcohol, paying special attention to the area around the scroll wheel.
  • Deep Cleaning your Mouse: If the problem persists, you can open the mouse and clean its internal components more thoroughly. Be sure to pay extra attention to the area around the switches that handle clicks.
2
Solution: Close any open applications and test the mouse's functionality
Some applications can hijack your mouse and interfere with its normal functions. Try closing any open applications to see if any are interfering with your mouse. Some of the following apps have been known to cause issues...
  • Browsers: Extensions can hijack mouse input. Try disabling them.
  • Games: The mouse button may be rebound to another function. Check game input settings.
  • Productivity software: Some CAD or design programs handle clicks differently; review their configuration.
3
Solution: Adjust your system settings
Your mouse clicks can be affected by your computer's settings. Double-check your system settings for anything that might impact how your mouse behaves.
Windows
Open Settings, Devices, then Mouse. Once in the Mouse page, make sure that your primary button is set to left. You'll also want to make sure that Turn on ClickLock is disabled, as this can affect how your mouse clicks.
MacOS
Open System Settings, then Mouse. Make sure that secondary click is set to Click Right Side.
Important
You will also want to check your computer's accessibility settings, as some accessibility features, such as sticky keys and drag lock, can interfere with how your mouse clicks behave.
4
Solution: Update mouse drivers
An outdated or corrupted mouse driver or a system driver (USB or Bluetooth adapter) can affect how your mouse interprets button clicks.
  • MacOS and Linux will use a generic driver for mice; however, if your mouse's manufacturer offers drivers on their website, try downloading the latest driver software from the manufacturer's site.
  • Windows 10 and 11 will automatically search for new drivers; however, you might need to prompt the operating system to install the latest drivers. Press the Windows Key and I to launch the Settings app, then choose Windows Update from the left menu. From there, select Advanced options, then Optional updates, then Driver Updates to search for the driver for your mouse.
Important
Keep in mind that if Windows can't find and update automatically, you may also need to go to the manufacturer's website.
5
Solution: Open the mouse and ensure the posts are aligned with the switches
Your mouse’s left and right buttons have small posts that translate physical motion into electrical signals to the switches inside. Misalignment of these posts with the input nubs of the switches, or a misaligned circuit board, can prevent the button's mechanical motion from reaching the internal switches.
  • Adjust your mouse's post position: Open up your mouse and loosen the screws holding down the circuit board. Move the board slightly to position the switch nubs directly under the posts from the buttons, then tighten the screws back down on the circuit board to hold it firmly in place.
  • Look for any internal damage: Pay special attention to your mouse switches.
Describe your problem in your own words
View statistics:
Past 24 Hours:15
Past 7 Days:134
Past 30 Days:560
All Time:1,657
