Dishwasher Troubleshooting: Fix Common Problems
The first step towards a working Dishwasher is identifying the problem. Select one of our preferred guides below to diagnose and solve Dishwasher common issues.
Not Draining
Is your dishwasher full of water at the end of your wash cycle? Is water leaking out onto the floor? Try these fixes.
Water
Dishwasher
Dishwasher
Not Cleaning
When you dishwasher stops washing the dishes, it has become obsolete. Follow this troubleshooting guide to get your machine running again.
Performance
Dishwasher
Dishwasher
Won't Turn On
Dishwasher won't power on? Try these fixes.
Power
Dishwasher
Dishwasher
Leaking
If you're experiencing pools of water on the ground, especially from the bottom of the door, your dishwasher is losing water. If it is an older plastic tub model, look for discolored areas and holes in the tub by shining a bright light under the unit and look in the tub for holes. If there is one, buy some waterproof epoxy to smear around the hole to plug the leak.
Water
Dishwasher
Dishwasher
Troubleshooting
Having a dishwasher malfunction can be frustrating, but often, the issues you encounter can be solved with some simple troubleshooting. This guide is designed to help you identify and resolve common problems with your dishwasher right at home. Whether you're dealing with a dishwasher that won't start, isn't cleaning properly, or has a leak, our straightforward steps will assist you in diagnosing and fixing the issue.
Dishwasher
Dishwasher
Stops Mid Cycle
Dishwasher stopped working or turned off mid cycle? Try these fixes.
Power
Dishwasher
Dishwasher
Not Drying
What to do when your dishes aren't dry at the end of a wash cycle? Try these fixes first.
Performance
Dishwasher
Dishwasher
Soap Pods Not Dissolving
When dishwasher soap pods don't dissolve, the dishes inside will remain dirty. Let's figure out the issue and make your glasses shine again.
Performance
Dishwasher
Dishwasher
Smells Bad
Pee-ew — Dishwasher leaving your kitchen smelly after a load? Follow this troubleshooting guide to solve problem of musty, fishy, or other gross smells from your machine.
Smell
Dishwasher
Dishwasher
Won't Drain
Water
Dishwasher
Dishwasher
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
LG Dishwasher - LDT7797
Power is fritzing after each cycle
See all 1 questions
