15% Off Selected iFixit Tools — Limited Time
Causes
An unstable wired or wireless connection causes trigger inputs to register occasionally or not at all.
Cause
If the controller is not securely connected to the device, trigger inputs may register intermittently or not at all. This can occur with both wired and wireless connections.
Solution
- Disconnect the controller and reconnect it.
- If using a wired connection, try a different USB port or cable.
- If you use Bluetooth or wireless mode, remove the device from your paired devices list and reconnect it.
- Restart the device you are using with the controller.
The system fails to interpret trigger signals correctly due to outdated or incompatible firmware or drivers.
Cause
Outdated firmware or drivers can cause inconsistent trigger responses because the system may not interpret the controller’s input signals correctly.
Solution
- Check for firmware updates using the Flydigi controller software.
- Update your system’s controller drivers.
- Restart your computer or console after updating.
- If problems continue, uninstall and reinstall the controller software.
Incorrect sensitivity settings or mapping configurations cause the trigger to behave unpredictably.
Cause
Incorrect trigger sensitivity settings or button mapping configurations can cause the trigger to behave inconsistently.
Solution
- Open the controller configuration software or system settings.
- Reset trigger sensitivity settings to default.
- Verify that the trigger is properly mapped in the game or application.
- Test the controller in another game or an input tester to confirm the issue.
Particles lodged in the trigger mechanism interfere with smooth movement and consistent input detection.
Cause
Dust, dirt, or small particles may become lodged around the trigger mechanism, preventing smooth movement or consistent input detection.
Solution
- Turn off the controller.
- Use compressed air to blow around the trigger.
- Gently clean the trigger area using a soft brush or cotton swab.
- Avoid inserting metal tools that could damage internal components.
If none of these solutions resolves the issue, the triggers may need to be replaced. Follow this guide for help with the Flydigi Apex 4 triggers.
- 30 - 45 minutesModerate
Describe your problem in your own words
