The Alienware Pro Wireless Gaming Mouse cursor is delayed, sluggish and moves slowly across the screen. Bigger than normal physical movement of the mouse are required for adequate response of the cursor. Follow this guide for potential fixes to the problem.
Causes
When the battery percentage of the mouse drops below a certain level, it can affect the mouse's response. Charge the mouse or use it in wired mode.
2
Physical damage, software issues, or power supply problems with your computer may cause a USB port to malfunction. Plug the wireless dongle into a different USB port on your computer.
3
Routers, cordless phones and other 2.4 GHz wireless devices can cause interference with the signal. Relocate all other 2.4 GHz wireless devices that are close to the mouse dongle.
4
The distance between the mouse and receiver may cause a weak signal. Connect the USB receiver to the long USB cable that comes with the mouse and place the receiver right next to your mousepad.
5
Dirt and debris build up can obstruct the mouse sensor’s communication with the mousepad. Use a cotton swab with isopropyl alcohol to gently remove dirt or dust. Ensure your mouse pad is clean and is not glossy or reflective. If the sensor is broken, use the Alienware Pro Wireless Gaming Mouse Optical Lens Replacement - iFixit Repair Guide to replace it.
6
The mouse's Dots Per Inch (DPI) setting, which controls cursor speed and sensitivity, may have been lowered. This can happen if the dedicated DPI button on the bottom of the mouse was accidentally pressed, or if Alienware Command Center (AWCC) sends a reset command.
There are multiple ways to fix this problem.
  1. Press the DPI button on the bottom of the mouse to choose the desired DPI.
  2. Update Alienware Command Center to the latest available version (v6.6 or later).
  3. Reset the mouse to factory defaults.
  4. Open Alienware Command Center (AWCC).
  5. Go to Settings > Update.
  6. Click Restore Factory Defaults and follow the on-screen instructions.
  7. Click the Save Preset button in AWCC.
7
If the computer polling rate is set too high, it can cause issues on older or outdated computers and systems. Lower the polling rate by following the instructions below.
  1. Open Alienware Command Center.
  2. Click the Alienware Pro Wireless Gaming Mouse image on the DASHBOARD.
  3. Go to the SYSTEM tab.
  4. Select ALIENFX PRESET.
  5. Choose SETTINGS from the right panel.
  6. Click DPI.
  7. The Polling Rate drop-down list is located at the bottom of the DPI level slider.
  8. Click the drop-down list.
  9. Select a lower polling rate.
  10. Click the Save Preset button.
8
When the battery percentage of the mouse drops below a certain level AND Pro-Mouse Battery Saver is ON in the Alienware Command Center (AWCC), the polling rate (or how often the mouse talks to the computer) will automatically lower to save power.
There are several ways to fix this problem.
  1. Charge the mouse or use it in wired mode.
  2. Update Alienware Command Center (AWCC) to the latest version. Dell has provided fixes in newer versions (v6.3 and later) that prevent the polling rate from dropping when Battery Saver Mode is active.
  3. Manually switch OFF Pro-Mouse Battery Saver in the Alienware Command Center.
  5. Navigate to the AlienFX section (or click on your mouse's image on the DASHBOARD).
  6. Select your Alienware Pro Wireless Gaming Mouse from the list of devices.
  7. Look for the Settings tab/section (or ALIENFX PRESET, then SETTING).
  8. Find the Battery setting.
  9. You should see an option to configure or enable Battery Saver mode (or a Battery Threshold option).
  10. If there is an explicit toggle switch (ON/OFF) or button for "Battery Saver mode": Switch it to the OFF position.
  11. If you see a slider for the "Battery Threshold" or "Battery Saver mode" percentage: Move the slider to the lowest possible percentage (e.g., 1%) to effectively disable the feature from activating during normal use or check for an "Off" setting associated with the slider.
  12. Click Save Preset to apply your changes.
9
If the mouse’s battery will not charge or drains quickly, the cursor will not respond normally. You may need to replace the battery. This Alienware Pro Wireless Gaming Mouse Battery Replacement - iFixit Repair Guide will walk you through, step by step, how to replace the battery.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:3
Past 30 Days:21
All Time:278
