Introduction
We stripped the iPhone 4 down to its basic components. Apple definitely spent time giving the phone a thorough makeover, meticulously changing every little facet. We are happy to splay the fruits of their labor for your enjoyment!
We have confirmed that the iPhone's A4 processor has 512 MB RAM, unlike the iPad's more limited 256 MB. This decision may have been made fairly late in Apple's development cycle, because early leaked prototype phones only had 256 MB.
Can't get enough? Follow @ifixit on Twitter.
You can also take a look at the the YouTube video slideshow of the teardown!
For more detailed technical information on the silicon inside the iPhone, be sure to check out Chipworks' in-depth analysis of the iPhone 4's components.
The world's most wanted device is now in the hands of the world's most foremost tinkerers!
The all-new iPhone 4 features upgrades from the 3GS including:
A redesigned glass & stainless steel body that shaves 3.5 mm off the width and is 3 mm thinner than the 3GS.
Choice of black or white coloring
Retina display featuring four times the pixel density of the 3GS
iOS 4 for multi-tasking
5 MP, 720p capturing rear-facing and VGA front-facing cameras
The iPhone 4's design is a dramatic departure from the aluminum and plastic drenched days that have plagued the iPhone in the past.
The rugged stainless steel bezels around the iPhone 4's perimeter double as both structural supports and antennas to boost reception.
Only time will tell if they absorb shock as poorly as the iPhone 3GS.
Shameless plug:
We also sell useful things, like Mac parts, iPad parts, and tools.
We'd expect our 32 GB iPhone 4 to fulfill its promise and give us, well, 32 GB. Unfortunately it has an actual capacity of 29.06 GB.
In terms of OS, the iPhone 4 comes preinstalled with the newly released iOS 4, build 8A293.
The iPhone 4 is Model A1332. Interestingly, that's a lower number than the A1337 iPad 3G.
It used to be called iPhone OS when there were just iPhones, now it's iOS.
32 MB as in 32*1000^3 - not 32*1024^3
When Apple says 32GB, it means 32,000,000,000B.
1KB is actually 1024B, 1MB is 1,048,576B (1024x1024), and 1GB is 1,073,741,824B
So 32,000,000,000B is actually 29.80GB.
Many manufacturers do the same.
Tool used on this step:Phillips #000 Screwdriver$5.49
Like the iPhone 3G and 3GS, there are two silver Phillips #000 screws at the bottom of the phone. Note: newer iPhone 4 handsets use 5-point "pentalobe" screws instead, requiring the use of a special screwdriver.
In a departure from the design of the 3G and 3GS, removing the screws releases the rear case, not the front glass.
This design makes switching out the rear panel trivial, but unfortunately means that replacing the iPhone 4 front panel will likely be rather challenging.
That's interesting... Apple's own gallery at http://www.apple.com/iPhone/gallery/ illustrates tiny torx screws. Maybe they still had a few leftover 00 Philips? :)
Erm, not sure why that P in the URL got capitalised. It should be lowercase, else you'll get a 404. I'd edit my note, but I can't see how to... and I missed a second l in Phillips... whoops!
yeah, I also remember torxs' from Apple gallery...weird ;)
grze -
I hope the screen is more durable during a drop (unlike everyone who says the previous iPhones bevels save the screen during a fall) or else the screen will be even more of a pain to fix.
Hey body! You're great as always!
One thing which is nothing to do with what you're doing, but I can't pass by without making a remark: Thanks for the care you've given to your fingernails:) I hate people with dirty fingernails! Keep up the good work.
We take pride in the quality of our hands!
The one that I bought in Japan had some weird 5-pointed screws instead of Phillips ones. That's annoying. They're not quite Torx and not quite Phillips.
As of September the iPhone 4 come installed with 2 5 point security torx screws.
Star-shaped torx + screw driver tool tools for iphone 4
Removing rear panel gives us a pretty good look at the iPhone 4's innards.
Holy battery! The inside of this thing is dominated by its juice-provider.
It's pretty apparent that real estate was very limited inside the iPhone 4's 115.2 x 58.6 x 9.3 mm footprint.
You can also see pressure contact on the inner face of the rear panel for what appears to be an antenna.
Could it really be? Just a little bit of user-serviceability?
Interesting that the back panel and battery are so easily removed. I'd love to see a third party make some back panels for something like conductive charging similar to the palm pre, or make a smaller sized battery to add some space in there to stuff some interesting little hacks. Maybe like a car remote or RFID stuff.
whats the contact and coating on the right side of the back (above the logic center) for?
Since it is in the shape of the logic board it looks like it may be an EMI shield, but it may also be an antenna (we're not 100% sure on what it is).
If it is shielding, then the conductive spot is connected to ground (battery, or case). If it is an antenna, then it is connected to an inductors pin.
Some Chinese-sourced backplates completely ignore this design detail and no one has complained about diminished functionality. However, if the shield is not on place, the FCC might say something for radiation pollution.
Luckily, the battery can be easily removed once the back panel assembly is out of the way.
The 3.7V 1420 mAh Li-Polymer battery allows for up to 7 hours of talk time on 3G or up to 14 hours on 2G.
The battery connector is different than the one in the 3G and 3GS. Fortunately, the battery is not soldered to the logic board. This will make battery replacement on the iPhone 4 fairly easy to accomplish.
The plastic pull tab for the battery says "Authorized Service Provider Only."
on the first picture of step 6. On the right hand, there is a piece : where it come from ? Where is it's place ?
thanks yous for your answer
It is a pressure contact that touches the rear panel, and its correct position can be seen in the third picture on this step.
The battery is glued into place and needs to be pried away, which will often deform the battery. So long as you do not puncture the casing, it should be ok to flatten it back into shape and reinsert it into the system. If you puncture the casing, you should get a new battery or risk excessive heat and possibly a risk of explosion.
How did you manage to get the battery out so cleanly?
battery is secured with a strong adhesive. simply pulling on the pull tab may result in tearing the tab off. you may need to pry it loose instead.
No EMI shield will stand between us and the innards of this iPhone 4!
The EMI shield comes off after five screws are removed to reveal lots of important connectors.
Upon further inspection, it looks like the EMI shield actually acts as the Wi-Fi antenna. The long screw at the top and center grounds the antenna.
Sorry to ruin the magic, but that "EMI shield" is actually the Wi-Fi antenna. The phone antenna is in the speaker enclosure removed in Step 12. The steel frame acts as a ground plane, not actually as a radiating antenna.
If thats the antenna no wonder they have problems!! (It's not)
The logic board is heavily embedded under wires and EMI shields.
While we're not too busy, let's talk RAM. Unlike the iPhone 3GS and iPad, which are both equipped with 256 MB, the iPhone 4 has a whopping 512 MB!
The increase in RAM allows for a larger amount of cached data allowing for a smoother and faster user experience.
Hiding in the corner is the iPhone 4's vibrator motor, which...well...vibrates.
thats not an accelerometer, thats the motor and weight for vibration, accelerometers are microchips and have no moving parts
Repairing an iPhone 4, but I don't have that screw as displayed in the photo. As a matter of fact the inside doesn't look the same. Also, the phone I am repairing does not have the SIM card on the side either. Am I missing something? I double checked. This is an iPhone 4...
You have a CDMA iPhone 4 which does not have a SIM card. Use this teardown instead: iPhone 4 Verizon Teardown
Behold a beauty in the iPhone 4: a rear-facing 5 MP camera with 720p video at 30 FPS, tap to focus feature, and LED flash.
This is a huge upgrade from the 3.2 MP camera found in the iPhone 3GS.
Looks like it's not a Philips Lumileds Luxeon LED like the rumor were stating after all. It's still yellow and this article says it should not be yellow: http://www.ledsmagazine.com/news/5/10/38
That's really too bad.
Apple doesn't seem to think so.
"Video recording, HD (720p) up to 30 frames per second with audio"
Is the iPhone's 4 Camera able to replace the iPhone 3Gs Camera? eg is it the same size etc...
Actually, the iPhone 3GS had a 3 megapixel camera. It says so on apple's website: http://www.apple.com/iphone/iphone-3gs/
Removing the lower antenna/speaker enclosure from the bottom of the phone.
The improved audio chamber aids in clarifying sounds leaving the iPhone, including calls via speakerphone as well as music played through the speaker inside this housing.
Apple hasn't made taking the iPhone 4 apart very hard so far: no 5-point Torx bits or fragile clips to be seen.
Removing the logic board.
The unusual shape and small size of the logic board shows just how costly real estate is inside this powerhouse of a phone.
you forgot to mention the 1 screw that are located under the white tab, that needs to be removed before removing the logic board
hi where can i find the logic board for iphone 4 gsm
doesn't give any instructions for logic board removal
Hi there! This is a teardown meant for entertainment purposes and should not be followed as a guide! Check the iPhone 4 device page for a full set of guides, including a step-by-step logic board replacement guide.
Apple has integrated the UMTS, GSM, GPS, Wi-Fi, and Bluetooth antennas into the stainless steel inner frame.
The dual purpose stainless steel inner frame/antenna assembly addresses possibly the two biggest flaws concerning previous iterations of the iPhone: continuous dropped calls and lack of reception.
Apple has gone a step further and tuned the phone to utilize whichever network band is less congested or has the least interference for the best signal quality, regardless of the actual signal strength. Early reports suggest this feature, while buggy in its early stages, will greatly improve the phone's reliability on AT&T's fragile network.
In 3GPP cellular networks, the decision to move from one frequency to another is up to the network to decide. The terminal can only say "I would like to go to this frequency or neighboring cell". Further it is not likely that the phone is measuring congestion of the network. Once again that is a parameter that the network should be monitoring and should be moving the terminals around (also called a handover) from cell to cell and frequency to frequency.
In reality, the AT&T network gear vendors have probably improved their handling of congestion.
As every high frequency engineer knows, touching an open antenna will detune it considerably. Was surprised to read about the open antenna design and subsequently the first reception problems with the design are reported.
yeah. NOT! Fail
With the EMI shields off, we can get a look at what makes this beast roar.
Lurking deep within the phone, the A4 processor, manufactured by Samsung, is the centralized unit that provides the iPhone 4 with the much needed computing power.
Replacing the Samsung S5PC100 ARM A8 600 MHz CPU used in the 3GS, the new iPhone uses the ARM Cortex A8 core, much like its bigger sibling, the iPad. The iPad's A4 is clocked at 1 Ghz.
Just to the left of the A4 package, the AGD1 is the new 3 axis gyroscope that we believe is designed and manufactured by ST Micro for Apple. The package marks on this device do not appear to be the currently available commercial part, L3G4200D. The commercial version of this gyroscope is yet to be released — Apple got first dibs on it.
The L3G4200D seems to be available indeed: http://www.st.com/stonline/products/fami...
What is the role of this piece? - http://prntscr.com/fnrxqj
On the top of logic board:
Skyworks SKY77542 Tx–Rx iPAC™ FEM for Dual-Band GSM/GPRS: 880–915 MHz and 1710–1785 MHz bands.
Skyworks SKY77541 GSM/GRPS Front End Module
STMicro STM33DH 3-axis accelerometer
TriQuint TQM676091
338S0626
I'm sorry, but what exactly are CDMA PA chips doing inside the iPhone?
Upon doing some research it seems the info listed in Step 16 is taken directly from a Sprint EVO 4G teardown from ChipWorks, for whatever reason. It's not the same list as on the iFixit teardown of the Sprint EVO 4G.
Also, the Triquint chip shown in the image is not the same number as shown in the associated text column. They do note this is a work in progress so we should give them some leeway, though posting erroneous info is pushing it, even if it is just a placeholder.
Nopw -
Would be Godsent. But definitely a mistake.
That CDMA information was incorrectly copied from a different report. My apologies; it has been removed.
You have CDMA parts listed in step 16. Was in 17 earlier, now in 16. I am seeing...
Step 16
Triquint TQM613029 CDMA PA-Duplexer Module.
Avago FEM7758 Front End Module
Triquint TQM13029 CDMA PA
Atmel M88PA MCU with eFlash
Silicon Image P1U0941 HDMI Processor
Samsung KBY00U00VM NAND Flash
Surely that is INCORRECT?
Based on examination of the photos, yes, it sure seems like that list is incorrect. One of the TriQuint chips sure looks like TQM676091, which doesn't seem to exist, but TQM676021 does exist and is an HSUPA chip.
That information was incorrectly copied from a different report. My apologies; it has been removed.
different photo? Where is the A4 Logo?
Nevermind, just the lighting.....FAIL
The 338S0626 appears to be an Infineon cellular baseband chip.
I see a 452 not a 542 on the skyworks chip. There is another skyworks chip I can't make out the number for. Can you guys clarify?
Please? This is wrong information.
On the back:
Samsung K9PFG08 flash memory
Cirrus Logic 338S0589 audio codec (Apple branded). This is the same part as in the iPad.
AKM8975 - newest magnetic sensor that promises to improve the performance over the prior generation.
Texas Instruments 343S0499 Touch Screen Controller
36MY1EE NOR and mobile DDR
Wi-Fi, Bluetooth, and GPS are all provided by Broadcom and located beneath EMI shields on the front side of the board.
Broadcom BCM4329FKUBG 802.11n with Bluetooth 2.1 + EDR and FM receiver.
Broadcom BCM4750IUB8 single-chip GPS receiver.
From Broadcom's site it says that the "Broadcom BCM4329FKUBG" is an FM TX and RX and not only RX.
From looking at the Broadcom site about that part it appears to be a utility chip that they rolled out to replace older parts (probably the ones in previous iPhones etc) The chip supports both 2.4 and 5ghz for full wifi a/b/g/n and includes the FM transmit and receive. Steve Jobs said in the Keynote that iPhone 4 supports wifi n at 2.4ghz only so FM Transmit won't be the only thing available on chip not in use.
However the main feature Apple probably looked at was the improved battery life and reduced 65nm process. The chip appears to serve Apple's engineering conditions and be not utilising some features they can reduce the draw on the power.
I don't think we will see FM Tx from this new device as I don't think we will see 5ghz wifi n (or wifi a). If they had an application of the tech ready to go Steve would have shown it off, as they didn't show it I don't think it will be activated later. However if they find a "compelling" reason to activate it we should see appearances in the next year and the hardware *could* support it.
Regards
Alexander
That means that probably we will see FM radio even in RX mode only? I wish that could be done with a software update and then the phone would be feature complete for me.
Thanks for the answer too. Answered a lot of my questions.
Regards
Dimitris
Dimitris -
The EMI shields were soldered onto the logic board. Those are extremely difficult to take off without making a mess.
Can the GPS chip be removed and the phone still be functional?
The front-facing VGA camera.
While the 5 megapixel camera on the rear of the iPhone 4 is ideal for video recording, the smaller camera on the front optimizes use of Apple's FaceTime for mobile-to-mobile video calls.
That oval copper thing in the center looks like a low-frequency inductor-type antenna. It has two spring leads that contact the back of the circuit board. Could this be used for near field communications/RFID?
oh wait, no way... that looks like a real speaker :-) false alarm!
The front panel comes off without too much additional trouble.
The stainless steel body left behind is quite a marvel of gadget engineering.
In step 21 is written "The front panel comes off without too much additional trouble". That is wrong for the iPhone 4 that I just took apart. The front panel is glued to the steel body very strong. There is no way to take these two things apart without extra tools like a hair dryer or heat gun to soften the adhesive. How do you explain that?
The front glass panel of the iPhone is reported to be constructed of Corning Gorilla Glass, a chemically strengthened alkali-aluminosilicate thin sheet glass that is reported to be 20 times stiffer and 30 times harder than plastic.
Gorilla Glass holds many advantages as the iPhone 4's front panel, including its high resistance to wear and increased strength from an ion-exchange chemical strengthening process.
LED Backlight for the LCD.
Unfortunately, the LCD panel is very securely glued to the glass and digitizer, with the entire assembly measuring 3.05mm thick. It appears that if you break the glass, you'll have to replace the iPhone 4's glass, digitizer, and LCD as a single assembly.
Front glass is Gorilla, but what about the back? I can't imagine it would be different, but I didn't see it mentioned.
How do you know that it is Gorilla Glass if Corning does not publicly release which devices are equipped with their glass? Additionally, the product information for the iPhone 4 calls it aluminosilicate glass, but it does not say that it is alkali-aluminosilicate. As you know, there are many applications of aluminosilicate glass other than alkali, including boron-aluminosilicate glass.
I'm hoping that the LCD being bonded to the glass will prevent dust from entering the display. All I know is that my original iPhone display is still beautiful and dust free, but my 3GS had dust between the glass and LCD within I week.
Hmm. I came here to try to figure out what the mysterious extra window is which appears in photos of the white iPhone 4, above the "receiver" ear slot. I think it's for a light sensor, and I assumed that it was also there on the black model, but just not visible because of the black surround.
http://www.engadget.com/2010/06/23/apple...
I think I can see it on my phone by using an LED flashlight to provide lots of illumination, but I'm not sure, and it doesn't seem to be there from the back in these photos.
Any ideas?
I believe I read that it is a contact sensor of sorts that detects when the phone is held up to your head (to turn off the display and prevent false presses on the touch screen).
cityzen -
Surprisingly, the electronic home button switch is attached directly to the home button itself.
"Surprisingly, the electronic home button switch is attached directly to the home button itself."
That would make it, the home button, very easy to replace in the event of failure; rather than having to change something on the logic board.
Let's hope the home button won't wear of due to excessive use of fast app switching.
Response to lint blocking the old switch?
Apple is following in the footsteps of the Nexus One by using dual microphones to help improve audio quality and suppress background noise.
Interestingly, the two microphones are positioned at the two far ends of the phone. The microphone at the top of the iPhone is most likely utilized for capturing background noise to be analyzed by internal circuitry and used to cancel any noise put into the main microphone other than the user's voice.
You can also see the ambient light sensor which adjusts the iPhone's brightness as lighting conditions change.
The proximity sensor sits right next to the ambient light sensor. This will turn the display off when you bring the phone up to your ear thus preventing any touch interaction while it's pressed up against ear.
As always, we provide each device with a fitting final layout shot that it so greatly deserves.
We would like to thank you for joining us tonight during this monumental endeavor.
We also created a set of iPhone 4 repair guides for all major components inside the device. They will definitely help you fix your iPhone 4 should something happen to it!
Tool used on this step:P2 Pentalobe Screwdriver iPhone$5.99
iPhone 4 Repairability Score: 6 out of 10 (10 is easiest to repair)
The iPhone 4 is held together primarily with [lots of] screws, sans tabs, and limited adhesive.
The rear panel and battery are both easy to remove and replace (provided you have the right kit and/or correct screwdriver).
Apple is using Pentalobe screws to secure the rear panel and keep people out.
The LCD and glass are fused together, making repairing a cracked front panel more costly.
During disassembly, your finger oils interfere with the iPhone 4's RF grounding contact points, so we recommend you wear gloves while performing any repairs.
This guide is useless
It's missing so much detail you'll almost definetly end up with a broken phone. Keep looking for a better guide.
This is just a teardown, not meant to be used as a repair guide. Check out the device page for 20 step-by-step guides.
24 Comments
Obviously creating antennas out of the frame pieces didn't work well for them... how obvious it should be that you should not touch an antenna and expect the radio to work. The "dual-band" enhancement is worthless - cellular got kicked off the 800-900 MHz spectrum.
EXTREAMLLY bad teardown guide. If It hadn't been for the fact that I have taken one apart before I would have killed the phone. No ref on screw sizes, no explanation on where force should be applied.............. REALLY BAD!!!!!!!!!
We are glad to hear that you are looking to our site for guidance. However, we would like to make sure you know that the Teardown Flag at the top of all teardowns explains, "Teardowns provide a look inside a device and should not be used as disassembly instructions." We strongly urge users not to follow teardowns, as they are intended for information and entertainment. Luckily, we have this extremely comprehensive list of guides (as opposed to teardowns) right here.
why have you left out each and every screw removal, to blab about the parts, not too detailed other than you like to bilge on about the features???
This guide is missing major steps. Use if you want to completed trash your iPhone and buy a new one. Worst guide in fixit I've found to date
Mitchell That's because this is a teardown, not a guide. There are 21 replacement guides here.
Good tear down but somebody should explain how the screws and for putting iPhone 4 back together! I personally have hard time and time consuming putting the screws back in I phone screen and case around the iPhone beezle. I am buy a ifix it mat because keep up with the screws headache .
Gracias, thanks,
thank you sir, I am very interested in what you did. iphone is be the best smartphone today. see also my article http://hargasmartphone.id/harga-iphone-7...
do you people break things down to see the components and to teach others whats inside an iphone or just for the heck of it?
Pretty sure it’s to teach people how to fix them. Don’t think it’s just for $@$** and giggles.
Do Iphone 4 and 4S have the same LCD, touch, digitizer and only plastic frame differ or not?
I've stripped down my iphone 4 and can't work out where this little brass part goes , it's got a angle with a hole for screwing it down and on the other side 2 little prones sticking up ps I thought it goes next to the back of the phones camera lense inside
Hi Colin, unfortunately this is a teardown meant for entertainment purposes, it’s not a repair guide. What part were you trying to replace? We may be able to help you find the relevant part of the correct guide to locate that spring contact. Otherwise, try checking through our repair manuals to find the component yourself. Best of luck!
I think you will have a breeze tearing down a WowWee MiPosaur. Only screws and a few connectors in this, besides one covered part or two!
I'd reposition each camera to be just above the respective camera holes. But awesome teardown guys! Thanks!
Cliff - Reply
good!
tuntunkyaw - Reply
