MacBook Pro Heat Sinks
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Choose your model of MacBook Pro:
Parts that work with MacBook Pro:
MacBook Pro 15" Retina (Mid 2015, Integrated Graphics) Heat Sink
This part attaches to the processor and helps dissipate heat.
MacBook Pro 13" Retina (Late 2013-Early 2015) Heat Sink
Replace a damaged heat sink. This part dissipates heat generated by your computer's processors.
MacBook Pro 13" Unibody (Mid 2012) Heat Sink
Replace a bent or damaged heat sink compatible with a mid 2012 model 13" MacBook Pro Unibody laptop.
MacBook Pro 13" Unibody (Early 2011-Late 2011) Heat Sink
MacBook Pro 16" (2019, 5300M/5500M) Heat Sink
Replace a damaged heat sink compatible with a 2019 model 16" MacBook Pro with an AMD Radeon Pro 5300M or 5500M GPU.
MacBook Pro 15" Retina (Late 2016-2019) Heat Sink
Replace a damaged heat sink compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 17" (Models A1212/A1229) Heat Sink
Attaches to processor and helps dissipate excess heat
MacBook Pro 17" (Model A1151) Heat Sink
MacBook Pro 15" (Model A1260) Heat Sink
Device Info
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
