MacBook Pro 15" Unibody (Mid 2010) Display Assembly
  • MacBook Pro 15" Unibody (Mid 2010) Display Assembly / Glossy / A-Stock
  • MacBook Pro 15" Unibody (Mid 2010) Display Assembly / Glossy / B-Stock
  • MacBook Pro 15" Unibody (Mid 2010) Display Assembly / High Resolution Glossy / A-Stock
  • MacBook Pro 15" Unibody (Mid 2010) Display Assembly / High Resolution Glossy / B-Stock
  • MacBook Pro 15" Unibody (Mid 2010) Display Assembly / High Resolution Anti-Glare / A-Stock
  • MacBook Pro 15" Unibody (Mid 2010) Display Assembly / High Resolution Anti-Glare / B-Stock
Our used options may have as many as three (3) dead pixels, per industry standard and may have cosmetic blemishes to varying degrees. Also, some parts may have outer housing that have been refurbished to remove dents and/or scratches. These refurbished parts may have a slightly different finish than an original part. The parts are fully functional.
$244.99
$244.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace your damaged screen with this display assembly.
This complete display assembly includes the iSight camera.
Note: The high resolution glossy or anti-glare displays are custom-to-order options. If you did not select this upgrade when purchasing your machine, you have the standard glossy display.
Compatibility
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
Repair Stories
User avatar
My Problem
Screen was broken and I decided to fix it instead of replacing the whole unit.
My Fix
We followed the instructions step by step and it went very well. The phillips screwdriver ended up not really working on the first set of screws but i had another that was better but other than that everything went really . . .
User avatar
My Problem
lending laptop to a drunken colleague
accidental drop
screen cracked
the struggle was real
My Fix
swimmingly. from the user:
Hi Chris -
I wanted to say a huge heart felt thank you for all of your help and patience in having my laptop repaired. Yesterday Valeria replaced the cracked screen and I am ful . . .
