MacBook Air 11” (Mid 2011 to Early 2015) Replacement Battery
New battery guaranteed at capacity greater than 4850 mAh.
$89.99
$89.99
We'll send a message when the product is back in stock.
Black Friday
Broken doesn't stand a chance.
Product Details
Features
Features
  • Replaces Apple laptop battery models A1406 and A1495 for Mid 2011 to Early 2015 11" MacBook Air laptops respectively.
This is an aftermarket replacement battery, NOT an Apple OEM part.
Note: Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Note: A small percentage of users have experienced issues with aftermarket (non-Apple) batteries failing to be recognized properly in devices running Mac OS X El Capitan (10.11.x) or Sierra (10.12.x). If your system does not operate properly with our replacement battery, it can be returned for a full refund.
Compatibility
MacBook Air 11" Early 2014
1.4 GHz (Early 2014)
1.7 GHz (Early 2014)
MacBook Air 11" Early 2015
1.6 GHz (Early 2015)
2.2 GHz (Early 2015)
MacBook Air 11" Mid 2011
1.6 GHz (Mid 2011)
1.8 GHz (Mid 2011)
MacBook Air 11" Mid 2012
1.7 GHz (Mid 2012)
2.0 GHz (Mid 2012)
MacBook Air 11" Mid 2013
1.3 GHz (Mid 2013)
1.7 GHz (Mid 2013)
Show 2 more devices
Repair Stories
User avatar
My Problem
Stealthy and lightweight laptop with a dead battery is just another surface to write on...that's not high tech!
My Fix
quick and easy. Boy, lots of dust collects in the cooling ducts though over 3+ years
My Advice
I found that the 5-point screwdriver worked fine to both remove the case cover and the battery screws
User avatar
My Problem
Battery was no longer holding charge, MBA indicated battery needs to be replaced
My Fix
I had incorrectly ordered the late 2010 battery, when it turned out I needed the late 2011 instead. Was able to obtain an RMA right away from ifixit and had the correct battery ordered.
The repair itself was simple, fol . . .
User avatar
My Problem
Just an old battery wihth a 30-minute life.
My Fix
Went easily, as advertized.
My Advice
Go to it. Battery replacement is a snap. You don't really need the spudger. the connector is finger-friendly.
P.S. I heard about Ifixit on the TWIT network.
