MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery
  • MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery / Fix Kit
  • MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery / Part Only
  • 360°
360
Note: This option does not include tools
$69.99
$69.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
This MacBook Air 11" (Mid 2011 to Early 2015) Replacement Battery Fix Kit is everything you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 4850 mAh. This fix kit comes with a brand new battery and all the tools you need to make the fix.
Note
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
A small percentage of users have experienced issues with aftermarket (non-Apple) batteries failing to be recognized properly in devices running Mac OS X El Capitan (10.11.x) or Sierra (10.12.x). If your system does not operate properly with our replacement battery, it can be returned for a full refund.
Warning
Lithium-ion batteries pose a fire hazard if they swell due to age or defect. Learn more about safe handling and proper disposal of all batteries.
Compatibility
MacBook Air 11" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 11" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 11" Mid 2011
1.6 GHz
1.8 GHz
MacBook Air 11" Mid 2012
1.7 GHz
2.0 GHz
MacBook Air 11" Mid 2013
1.3 GHz
1.7 GHz
Show 2 more devices
Repair Stories
Adalsteinn Hjalmarsson's Story Photo #910862
Adalsteinn Hjalmarsson's Story Photo #910864
Adalsteinn Hjalmarsson's Story Photo #910865
My Problem
Swollen Battery. Computer looked like it was going to explode.
My Fix
Easy with the iFixit Guide and iFixit Tools
My Advice
Use good lighting, right tools, be uninterrupted and have time.
Robert's Story Photo #1371898
My Problem
My aged MBA was losing battery power very quickly.
My Fix
I was able to easily order the correct materials using their links in the directions. The repair went exactly as it showed in the directions. It was extremely simple and straightforward using their descriptions and pictures. The difficulty and time . . .
Steven  OConnor's Story Photo #1140101
My Problem
Replaced the battery easily.
My Fix
Without a hitch—just have the right sized tools to remove screws from case and battery. If not you may run into a problem.
My Advice
Proper tools take pictures before you disassemble. Keep parts organized while disassembled for easier reassembly. Take note of where longer screws g . . .
My Problem
Original battery would not hold charge.
My Fix
The easiest repair (with the correct tools).
My Advice
Have some canned air available to blow out dust bunnies. Store screws in safe place before you starts blowing out any accumulated dust.
My Problem
Dead battery
My Fix
I followed the instructions on the video and it went well without a hitch. First time opening up a Mac laptop. I appreciated how you gave suggestions on which tools to order to do the job right.
My Advice
I appreciated how you gave suggestions on which tools to order to do the job right. My advi . . .
My Problem
My battery is getting old and i needed to replace it
My Fix
Very easy as i have the fixit utility tool kit i was able to have the right tools at the right time
My Advice
just follow the steps!!!
My Problem
Spilled a little fluid onto macbook
My Fix
lt worked while plugged in. Took it to try the Apple genius bar. They said I had fluid all over the components and that it would cost $750 plus tax to fix. I then took it to my friend from work who knows a lot about computers. He ran diagnostics and the system told . . .
My Problem
The battery on the Macbook Air wasn't last longer than 10 minutes. The battery icon was also indicating to replace the battery.
My Fix
Very quick and easy
My Advice
This is indicated in the repair guide but the Macbook air does not use torx screw driver for the outside casing as well as for the battery
My Problem
Batteries were broken due to age not loading cycles
My Fix
As the 2011 Macbook Airs are not filled with glue (as the newer models) it just took the 2 right screw drivers and 15 minutes per device (a 11 and a 13 inch MB Air).
My Advice
The ifixit guide gives you the perfect security and support that you can perform th . . .
My Problem
The battery had swollen.
My Fix
Very simple repair, just make sure you have a container for the little screws (which are of different lengths).
My Advice
I suggest that as you take them out, you stick them to a piece of tape—that way they are easy to keep in order and not to lose.
Show more
