MacBook Air 11" (Mid 2011/Mid 2012) Battery
Used battery guaranteed at capacity greater than 4310 mAh (90% of the design capacity) with fewer than 100 load cycles.
Condition: Used
$59.99
$59.99
We'll send a message when the product is back in stock.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Product Details
Features
Features
This is an Apple original (OEM) battery.
Note: Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Compatibility
Repair Stories
User avatar
Adalsteinn Hjalmarsson's Story Photo #910862
Adalsteinn Hjalmarsson's Story Photo #910864
Adalsteinn Hjalmarsson's Story Photo #910865
My Problem
Swollen Battery. Computer looked like it was going to explode.
My Fix
Easy with the iFixit Guide and iFixit Tools
My Advice
Use good lighting, right tools, be uninterrupted and have time.
User avatar
Steven  OConnor's Story Photo #1140101
My Problem
Replaced the battery easily.
My Fix
Without a hitch—just have the right sized tools to remove screws from case and battery. If not you may run into a problem.
My Advice
Proper tools take pictures before you disassemble. Keep parts organized while disassembled for easier reassembly. Take note of where longer screws g . . .
User avatar
My Problem
My battery is getting old and i needed to replace it
My Fix
Very easy as i have the fixit utility tool kit i was able to have the right tools at the right time
My Advice
just follow the steps!!!
User avatar
My Problem
Batteries were broken due to age not loading cycles
My Fix
As the 2011 Macbook Airs are not filled with glue (as the newer models) it just took the 2 right screw drivers and 15 minutes per device (a 11 and a 13 inch MB Air).
My Advice
The ifixit guide gives you the perfect security and support that you can perform th . . .
User avatar
My Problem
The battery had swollen.
My Fix
Very simple repair, just make sure you have a container for the little screws (which are of different lengths).
My Advice
I suggest that as you take them out, you stick them to a piece of tape—that way they are easy to keep in order and not to lose.
User avatar
My Problem
The battery was dead!
My Fix
The battery arrived ahead of schedule and the repair went very smoothly.
Thank you very much.
Andrea Klanderman
My Advice
Order a new battery.
User avatar
My Problem
I have had the MacBook sense 2011 and recently have dealt with power issues. Battery status indicated that a replacement was needed.
My Fix
I downloaded and printed the Very easy to read and follow instructions that IFixit provided, along with the replacement battery, which was easy to locate and order fro . . .
User avatar
My Problem
Battery life was only about 2, 2.5 hours.
My Fix
Amazingly easy! I was hesitant about opening up a Macbook Air -- I always heard how the battery was not "user repairable." With iFixit's tools and instruction guide, the entire battery replacement took only 10 minutes.
My Advice
Don't be worried -- it's much, much eas . . .
User avatar
My Problem
I've bought ifixit battery + a couple of screwdrivers. Spent about 40 minutes to replace the battery by myself.
My Fix
Great. I consider it to be very easy.
My Advice
Prepare 3-4 different places to store the bolts.
User avatar
My Problem
Macbook Air battery was not holding a charge.
My Fix
This was a 10 minute swap. The screw drivers recommended by ifixit are a must.
My Advice
Double check that you are ordering the correct battery. The first part of the model number matches multiple years for the Air. I didn't know this and ordered the wrong battery. . . .
Show more
