iPhone 7 Power and Volume Control Cable Replacement
  1. iPhone 7 Power and Volume Control Cable Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Power and Volume Control Cable Replacement, iPhone 7 Opening Procedure: step 2, image 1 of 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Power and Volume Control Cable Replacement: step 3, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 3, image 2 of 2
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Power and Volume Control Cable Replacement: step 4, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 4, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 4, image 3 of 3
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. iPhone 7 Power and Volume Control Cable Replacement: step 5, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 5, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 5, image 3 of 3
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. iPhone 7 Power and Volume Control Cable Replacement: step 6, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 6, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 6, image 3 of 3
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. iPhone 7 Power and Volume Control Cable Replacement: step 7, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 7, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 7, image 3 of 3
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. iPhone 7 Power and Volume Control Cable Replacement: step 8, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 8, image 2 of 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 Power and Volume Control Cable Replacement: step 9, image 1 of 1
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 Power and Volume Control Cable Replacement: step 10, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 10, image 2 of 2
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. iPhone 7 Power and Volume Control Cable Replacement: step 11, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 11, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 11, image 3 of 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  12. iPhone 7 Power and Volume Control Cable Replacement, Battery Disconnection: step 12, image 1 of 1
    Tool used on this step:
    Tri-point Y000 Screwdriver
    $5.99
    Buy
  13. iPhone 7 Power and Volume Control Cable Replacement: step 13, image 1 of 1
    • Remove the lower connector bracket.
  14. iPhone 7 Power and Volume Control Cable Replacement: step 14, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 14, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 14, image 3 of 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. iPhone 7 Power and Volume Control Cable Replacement, Display Assembly: step 15, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement, Display Assembly: step 15, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement, Display Assembly: step 15, image 3 of 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. iPhone 7 Power and Volume Control Cable Replacement: step 16, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 16, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 16, image 3 of 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  17. iPhone 7 Power and Volume Control Cable Replacement: step 17, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 17, image 2 of 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. iPhone 7 Power and Volume Control Cable Replacement: step 18, image 1 of 1
  19. iPhone 7 Power and Volume Control Cable Replacement, SIM Card: step 19, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement, SIM Card: step 19, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement, SIM Card: step 19, image 3 of 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  20. iPhone 7 Power and Volume Control Cable Replacement, Logic Board Connectors: step 20, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement, Logic Board Connectors: step 20, image 2 of 2
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
  21. iPhone 7 Power and Volume Control Cable Replacement: step 21, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 21, image 2 of 2
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
  22. iPhone 7 Power and Volume Control Cable Replacement: step 22, image 1 of 1
    • Remove the bracket.
  23. iPhone 7 Power and Volume Control Cable Replacement: step 23, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 23, image 2 of 2
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
  24. iPhone 7 Power and Volume Control Cable Replacement: step 24, image 1 of 1
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
  25. iPhone 7 Power and Volume Control Cable Replacement: step 25, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 25, image 2 of 2
    • Remove the upper cable bracket.
  26. iPhone 7 Power and Volume Control Cable Replacement: step 26, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 26, image 2 of 2
    • Use the flat end of a spudger to disconnect the upper cable connector.
  27. iPhone 7 Power and Volume Control Cable Replacement: step 27, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 27, image 2 of 2
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
  28. iPhone 7 Power and Volume Control Cable Replacement: step 28, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 28, image 2 of 2
    • Remove the top left antenna.
  29. iPhone 7 Power and Volume Control Cable Replacement: step 29, image 1 of 1
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
  30. iPhone 7 Power and Volume Control Cable Replacement: step 30, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 30, image 2 of 2
  31. iPhone 7 Power and Volume Control Cable Replacement: step 31, image 1 of 1
    Standoff Screwdriver for iPhones
    $5.49
    Buy
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  32. iPhone 7 Power and Volume Control Cable Replacement: step 32, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 32, image 2 of 2
    Buy
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  33. iPhone 7 Power and Volume Control Cable Replacement, Logic Board: step 33, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement, Logic Board: step 33, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement, Logic Board: step 33, image 3 of 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  34. iPhone 7 Power and Volume Control Cable Replacement: step 34, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 34, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 34, image 3 of 3
    Buy
    • Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
  35. iPhone 7 Power and Volume Control Cable Replacement: step 35, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 35, image 2 of 2
    • Use the point of a spudger to disconnect the lower cable connector.
  36. iPhone 7 Power and Volume Control Cable Replacement: step 36, image 1 of 1
    $5.49
    Buy
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using a standoff driver.
  37. iPhone 7 Power and Volume Control Cable Replacement: step 37, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 37, image 2 of 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
  38. iPhone 7 Power and Volume Control Cable Replacement: step 38, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 38, image 2 of 2
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
  39. iPhone 7 Power and Volume Control Cable Replacement: step 39, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 39, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 39, image 3 of 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
  40. iPhone 7 Power and Volume Control Cable Replacement, Barometric Vent: step 40, image 1 of 1
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
  41. iPhone 7 Power and Volume Control Cable Replacement: step 41, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 41, image 2 of 2
    • Remove the vent.
  42. iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable Battery: step 42, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable Battery: step 42, image 2 of 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  43. iPhone 7 Power and Volume Control Cable Replacement: step 43, image 1 of 1
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
  44. iPhone 7 Power and Volume Control Cable Replacement: step 44, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 44, image 2 of 2
    • Remove the Taptic Engine.
  45. iPhone 7 Power and Volume Control Cable Replacement: step 45, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 45, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 45, image 3 of 3
    Buy
    • Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
  46. iPhone 7 Power and Volume Control Cable Replacement: step 46, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 46, image 2 of 2
    • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
  47. iPhone 7 Power and Volume Control Cable Replacement: step 47, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 47, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 47, image 3 of 3
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  48. iPhone 7 Power and Volume Control Cable Replacement: step 48, image 1 of 1
    • Repeat the previous step for the second strip.
    • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
    • If you removed both adhesive strips successfully, skip the next step.
    • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
  49. iPhone 7 Power and Volume Control Cable Replacement: step 49, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 49, image 2 of 2
    Plastic Cards
    $2.99
    Buy
    • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Avoid bending the battery. Damage to the battery may release dangerous chemicals, and could start a fire.
    • Do not pry under the top third of the battery, you may damage the volume button ribbon cable.
  50. iPhone 7 Power and Volume Control Cable Replacement: step 50, image 1 of 1
    • Remove the battery.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
  51. iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable: step 51, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable: step 51, image 2 of 2
    • Two 1.9 mm screws securing the power button.
    • Three 2.3 mm screws securing the volume buttons.
  52. iPhone 7 Power and Volume Control Cable Replacement: step 52, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 52, image 2 of 2
    • Remove the following 1.3 mm Phillips screws:
    • One screw beside the rear-facing camera
    • One screw on the rear case
  53. iPhone 7 Power and Volume Control Cable Replacement: step 53, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 53, image 2 of 2
    • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
    • This action will free the hold switch and gasket from the rear case.
  54. iPhone 7 Power and Volume Control Cable Replacement: step 54, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 54, image 2 of 2
    • Use a pair of tweezers to remove the rear-facing camera.
  55. iPhone 7 Power and Volume Control Cable Replacement: step 55, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 55, image 2 of 2
    • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
  56. iPhone 7 Power and Volume Control Cable Replacement: step 56, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 56, image 2 of 2
    • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
  57. iPhone 7 Power and Volume Control Cable Replacement: step 57, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 57, image 2 of 2
    • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
    • Remove the antenna flex cable.
  58. iPhone 7 Power and Volume Control Cable Replacement: step 58, image 1 of 1
    • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
    • Standoff screws are best removed using an [linked product missing or disabled: IF145-343] and driver handle.
  59. iPhone 7 Power and Volume Control Cable Replacement: step 59, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 59, image 2 of 2
    • Remove the flash bracket.
  60. iPhone 7 Power and Volume Control Cable Replacement: step 60, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 60, image 2 of 2
    • Use the point of a spudger to gently unseat the flash module.
  61. iPhone 7 Power and Volume Control Cable Replacement: step 61, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 61, image 2 of 2
    • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
  62. iPhone 7 Power and Volume Control Cable Replacement: step 62, image 1 of 2 iPhone 7 Power and Volume Control Cable Replacement: step 62, image 2 of 2
    • Gently fold the power button module from the edge of the rear case.
  63. iPhone 7 Power and Volume Control Cable Replacement: step 63, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 63, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 63, image 3 of 3
    • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
    • Continue to separate the adhesive by moving the blade towards the top of the phone.
  64. iPhone 7 Power and Volume Control Cable Replacement: step 64, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 64, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 64, image 3 of 3
    • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
    • Move slowly to make sure that the cable is not damaged during removal.
  65. iPhone 7 Power and Volume Control Cable Replacement: step 65, image 1 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 65, image 2 of 3 iPhone 7 Power and Volume Control Cable Replacement: step 65, image 3 of 3
    • Slide the halberd spudger under the volume control portion of the button cable.
    • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
  66. iPhone 7 Power and Volume Control Cable Replacement: step 66, image 1 of 1
    • Remove the power and volume control cable.
Scott Havard
49,705 Reputation
31 Guides authored
Past 24 Hours: 14
Past 7 Days: 35
Past 30 Days: 226
All Time: 43,182
